Look What I Got Today!
Depending on price I would be in on the group buy for an 06 G35 coupe.
from what i know, it is designed to fit the 07 sedans. i double checked with the guy before i ordered it.
I have access to a CNC so I was thinking about a momentum performance style with a hurst shifter grip and some engraving on the sides and/or laser etched shift pattern on the top. The other option would be a forged performance style. Both would be 400 series stainless. Let me know what you guys think.
I was trying to find someone with a cnc FOREVER to cut a tommy kaira style ****. Then I caved in and bought one because I couldn't find anyone that would machine a small run for less than what they actually cost.
If you're interested I should still have the dimensions for it in cad format.
Also, something I got today.....
Custom Altima Push Button Start Kit for S30/510.
Mounts right into the stock location (minus original ignition) Can't wait to install it!
Here's the link: http://community.ratsun.net/topic/29...nition-system/
Might work on other ignition systems....
Button has ACC and ON. You push the brake and push again and it starts. It has a built in security/disable switch
and you can wire that into the alarm if wanted. Check out the link in post# 1434....
