Other Cars Other Cars classifieds
1993 twin turbo rx7
Old Jun 10, 2009 | 07:01 PM
DG_coupe's Avatar
1993 twin turbo rx7
Up for sale is a 1993 rx7 I'm posting this strictly for a good friend and all the info and pics are from him directly his asking price is 10,000 or best offer
Update: The car had a salvage title, but everything is fine with the car and engine was rebuilt
Reason for Selling: he wants to get a evolution
Vin number: can be sent on request
Best Contact: 617 777 8762
INFORMATION HE SENT ME
1993 Mazda Rx7 Twin Turbo Touring car dynoed at 330 whp
SPECS / MODIFICATIONS:
ENGINE
-Urethane motor mounts
-Apexi Power FC Stand Alone EMS with PFC Commander
-13b-rew freshly rebuilt
-Large Street exhaust ports
-Judge Ito large Intake ports (Both Primary and Secondary Ports)
-OEM 2mm apex seals
-OEM Side Seals
-Atkins solid corner seals
-Viton Oil O-rings
-SS Oil Metering pump lines
-Indigo Under drive alternator & H20 pump Pulley
-All emissions removed
-Air Pump Removed
-Dual Oil coolers
TURBO
-Full Non-Sequential modifications performed
-Ported Turbo (Pre-spool area has been ported and blended into secondary turbo feed area)
-Ported Wastegate (No Boost Creep)
-Stock twins with very little shaft play (within spec)
-No Smoking
EXHAUST SYSTEM
HKS Down pipe
3” Stainless Steel Rx7store.net Resonated mid pipe
3” Stainless Steel Apexi Dual N1 exhaust w/ dual silencers
New exhaust gaskets (Motor to turbo, turbo to DP, DP to MP & MP to Cat Back)
ELECTRONICS / GAUGES
- Apexi Power FC Stand Alone EMS with Commander Programmer
-Innovate Motorsports LC1 & XD1 gauge Wideband system
-Greddy Profec B Spec II boost controller
-Auto meter Vac/Boost gauge
-Pioneer CD/CDR head unit.
-Optima Red Top Battery (Relocated to Rear)
-New OEM Map sensor
COOLING SYSTEM
-Stock radiator
-Throttle body heating loop disabled
ACCESSORIES / MISC.
-The A/C system is newly recharged (ICE COLD!)
-All bolts removed replaced with stainless steel fasteners
-Engine bay painted gloss black
-All accessories and engine bolt-ons coated with Hi temp silver or black then hi-temp cleared.
-All fluids and filters freshly changed.
INTAKE SYSTEM
-Polished Aluminum hard pipes with K&N filters
-Ported partition out of the UIM (Secondary air passage is one passage now instead of 2 separate to match the throttle body)
-Idle Air controller is still being used.
-Secondary Butterflies removed
-Greddy Polished aluminum Compression Elbow
-Greddy Polished aluminum 2 Row newer style FMIC
-Greddy Type RS Blow off Valve
-Removed Charge control flapper from upper Y pipe. (Part of full sequential Modification)
-New Polished aluminum upper intercooler pipe
-New 4 Ply Silicone intercooler couplers.
FUEL SYSTEM
-New Walbro fuel pump
-Fuel Filter Relocated and replaced with new OEM filter @ 54,598
-Freshly cleaned and flow balanced 550cc Primary Injectors from RC Engineering
-Freshly cleaned and flow balanced 1300cc Secondary injectors from RC Engineering
-Using stock rails and FPR
-Fuel cut solenoid has been removed
DRIVETRAIN
-B&M Short through shifter
-9lb SR Motorsports Aluminum flywheel
-Clutch net 6 Puck clutch
-ACT 2600 lb. Extreme pressure plate
-New Pilot bearing & seal
-New Through-out bearing
-80w-140 Royal Purple Gear max lube (Trans)
-75w-90 Royal Purple Gear Max lube (Differential)
IGNITION
-Magnecore 10mm Wires
-Denso #9 Leading plugs
-Denso #9 Trailing plugs
INTERIOR
-Greddy Counterweighted threaded shift ****
-Italian Red Stitched real leather shift & E-Brake boot
-Grant Red/Black Leather steering wheel
EXTERIOR
-Stock wheels coated black (New Tires)
-99 Spec Taillights
-R1 Strut bar, Front lip, Rear wing.
any questions please feel free to call him or ask me I'll do my best to answer them
Old Jun 11, 2009 | 02:30 PM
DG_coupe's Avatar
bump willing to take reasonable offers
g.spot
May 9, 2016 10:54 PM
dorifto7
Sep 17, 2015 04:53 AM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
