(-) Negative Three (-)
Old Jul 15, 2007 | 01:53 AM
redlude97's Avatar
Originally Posted by aHero4Eternity
he's @ -2.8 and i'm @ -2.9/-3.1 right now.
i just want to be able to get back below -2.0 (preferably around -1.5~-1.8)
i just have to find it in me to buy the 350evos...
So is your arm currently at the stock location or do you have some positive camber adjustment dialed into the SPC's? I think he was at -2.8 with the stock arms, and then adjusted them to get back within spec. With stock arms you are probably in the -3.5 range.
Old Jul 15, 2007 | 02:06 AM
Calvin's Avatar
Overglorified Altima
i'm as positive as i can get with these arms.
ideally, i'd be happy with -2.0 all around (though i'd prefer the prior mentioned specs). but right now, i can't justify spending an extra 5 bills to get +1.0 degree more.
so as far as spacers go, i'll look into them and get some when i can afford them.
i've got other things on my mind to purchase.
Old Jul 15, 2007 | 01:30 PM
robzone's Avatar
Id suggest using some spacers since your average offset wheels look to sunk in 8) i guess Ill be coming up with my "negative 4.5" thread here pretty soon to accomodate my works
Old Jul 15, 2007 | 01:37 PM
Calvin's Avatar
the offsets may be "average," but the lips aren't.
Old Jul 15, 2007 | 01:41 PM
robzone's Avatar
most people have 3 and 4 inch lips on this site front and back. wanna measure?
Old Jul 15, 2007 | 01:44 PM
Calvin's Avatar
i rarely see 3" [tue] lips in the front.
even if 3" lips are common on this site, they're not common on a 9.5 vs-xx wheel (not on this site at least) as i'm the only person on this site with 9.5/10.5 +24 all around.
the majority of people with vs-xx are running [Front] 19x9.5 Offset: +28(R) , [Rear] 19x10.5 Offset: +29(O)
alvin, i believe, is running like a +17 or something up front...but the lips aren't 3"
even shawn, with 20" vs-xx, doesn't have a 3" lip in the front (doesn't look like it from the pics, at least).
Old Jul 15, 2007 | 01:55 PM
Land Shark's Avatar
QX70S, IPL, NISMO 370Z, S5
Well
If you want to talk about lip size, U DO NOT even come close to the over 4 in front and over 5 in rear that ROBZONE is going to be running not to mention his +13 and +6 offsets. HOTTNESS!
Just an FYI
Old Jul 15, 2007 | 02:00 PM
Calvin's Avatar
Just an FYI
my offsets don't require spacers in the front to clear my [puny] stock calipers.
i also don't have to run stretch tires (not my taste at all). i give him props for running such an aggressive setup, tho.
/done
Old Jul 15, 2007 | 03:04 PM
Ciabatta Burger's Avatar
not just the only person running that offset im running that on my Volk Gt-7s with 3.5 front lip and a tid over 4 on the rear
Old Jul 15, 2007 | 03:20 PM
GreenGoblin's Avatar
The goblin resurrection
looks good I bet it handles like its on rails
Old Jul 15, 2007 | 03:56 PM
redlude97's Avatar
Notice he said on vs-xx's. The reason most people's lips are small on the vs-xx's is because the spokes are straight, they are true big lips because the spokes don't curve in towards the edges like on your gt-7's. Your 3.5" lip is also measured inbetween your spokes since the volks recess into those areas, while a true lip does not. Not really the same comparison anymore is it?
Old Jul 15, 2007 | 04:14 PM
Hexxum001's Avatar
Damn, you really don't like your tires do you Calvin.
Old Jul 15, 2007 | 04:18 PM
redlude97's Avatar
Calvin,
I am interested in how you got +24 offset front and rear since they aren't listed on the work spec sheet. I'm guessin you are running an a-disk up front, and a 0 disk in the rear? A 9.5(A) +32 has a 3" lip already, so if yours are indeed +24, then your lip must be bigger than 3", and a 19x10.5(o) +29 has a 4" lip, again your lip should be larger.
Old Jul 15, 2007 | 04:23 PM
98intrigue's Avatar
actually, i was thinking about doing that already.
http://img.auctiva.com/imgdata/0/1/9...2283011_tp.jpg
(totally kidding. sort of.)
thanks.
i gotta give that to mike (imalazeeass), tho. he's gotta damn clean DG, as well.
I guess I'm not up for nomination because of my stock sides?
Old Jul 15, 2007 | 04:49 PM
  #30
by15vc's Avatar
for some reason i was always under the impression that imalazeeass had a ob g
