Oem 19's Appreciation Pic Post
Old Jul 23, 2012 | 11:12 AM
  #826
My Key's Avatar
Old Jul 23, 2012 | 12:15 PM
  #827
My Key's Avatar
instagram fun
Old Jul 23, 2012 | 12:21 PM
  #828
JaE35's Avatar
Moderator
G35 Sedan
The stock finish compliments OB so well...maybe i'm biased lol
Old Jul 23, 2012 | 12:24 PM
  #829
My Key's Avatar
probably biased... but so am i.
Old Jul 24, 2012 | 03:49 AM
  #830
cowboys13's Avatar
My Key, what are you lowered on? I want my front as low as yours.
Old Jul 24, 2012 | 11:06 AM
  #831
My Key's Avatar
I'm lowered on TopSpeed MDU's or whatever they're called. lol. I can go lower on the fronts, but then I lose the ability to turn.
Old Jul 24, 2012 | 12:32 PM
  #832
Algy's Avatar
Do u have any close ups of the front so I can see how close your wheels are to your fenders.. I'm looking for the biggest spacer I can run in the front and stay slammed with stock camber specs.. thanks
and this is how it sits
Old Jul 24, 2012 | 12:46 PM
  #833
DaveNYC's Avatar
From this past weekend.. tires are F: 245/35 R: 255/35
Old Jul 24, 2012 | 12:54 PM
  #834
Frankieg35's Avatar
I'm about that low also algy.. Are u on 35 series tires?? Do u think a 25 mm spacer would rub on the fenders??
Old Jul 24, 2012 | 01:21 PM
  #835
Algy's Avatar
Im on the original 40 series tires which should be the OEM size.
Depending on your camber you could run 25mm. I only rub slightly on the inner clip lining and fender.
I know this bc once I approach a incline and pull in while angling it. I hear this rub (metal to metal or rubber contact). As I check the fender, I find all this tire shine on the upper fender.
Old Jul 24, 2012 | 03:13 PM
  #836
DaveNYC's Avatar
Well with 255/35 In the rear and being low I'm sitting naturally flush and my fenders are rolled. My fronts could use 10-15mm tops. 25mm sounds like a lot to me.
EDIT:
Old Jul 24, 2012 | 03:20 PM
  #837
Big Booty Trudy's Avatar
Algy it looks really good! Loving the stock look. I'm hoping to get some coilovers pretty soon to drop it like yours.
Old Jul 24, 2012 | 03:39 PM
  #838
Frankieg35's Avatar
I'm converting back the stock fenders that aren't pulled and oem camber.. I'm on 30/35 now with pulled front fenders and 2+ degrees of negative camber.. I'm thinking of putting the 30mm spacer on the back and get 20 or 25 for the front.. I put 35 series tires on my oem 19s, 40s looked to fat to me..
Old Jul 24, 2012 | 08:00 PM
  #839
cowboys13's Avatar
Looks sick Algy! I think im gonna chrome out my wheels, what do you guys think of black chrome?
Old Jul 24, 2012 | 08:05 PM
  #840
Frankieg35's Avatar
Do it!!
