20mm spacers front/rear on OEM 17" Coupe rims
Old Mar 6, 2008 | 02:55 PM
Loe G35's Avatar
Originally Posted by SIN3
what are we looking at here? closer pics maybe? looks the same from that far away. nice snow.
pic w/o spacers:
another one (not mine)
Old Mar 6, 2008 | 02:58 PM
redlude97's Avatar
Originally Posted by Loe G35
The front 19X8's basically flushed with the 20mm spacers. If I remove the spacers, it'll be too tucked compared to the rears. Since the rears at a half inch wider (but with a 33et offset), but should push the wheel out farther up front running 19x8.5" 33et w/o spacers vs. 19x8" 30et w/o spacers without making it look completely flushed.
I understand there will be less contact patch even though I'm running 245's all around since there is a .5" difference in wheel width.
It's hard for me to explain the look I'm going for so I'm just going to try it.
The difference is only +3mm, and combined with a more stretched tire on your 8.5" rim is going to net you a wheel that appears as tucked as stock. You will need at least a 10mm spacer to notice any difference at all
Old Mar 6, 2008 | 03:02 PM
Loe G35's Avatar
I should just sell my 20mm spacer and buy a 10-15mm for the fronts
Old Mar 6, 2008 | 05:32 PM
redlude97's Avatar
that is what you should do
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
BlackGee35
Jul 23, 2015 01:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
