Old Nov 8, 2010 | 04:06 PM
  #17221
erklep's Avatar
marcus, ive always HEARD 10 mm. i cant say for sure. but wouldnt it also depend a touch on what size/brand of tires he runs?
Old Nov 8, 2010 | 04:09 PM
  #17222
CandlestickPark's Avatar
ill Sedan
Yes, not considering tire brand yet, but that would be a consideration too. I'm assuming he'll go with the same tire brand he's currently running.
Old Nov 8, 2010 | 05:36 PM
  #17223
eurodre's Avatar
generally its 1 degree of camber= 5mm of space but that of course gets blurred when you introduce the fender work which by doing a little more of can prevent having to add more neg camber to a certain extent
but yes 1 degree of camber=5mm of space
but you don't really go by that, it's not sooo technical, once the car is getting its alignment you go by sight
Old Nov 8, 2010 | 08:23 PM
  #17224
MIA Philly's Avatar
[QUOTE=nitsuj;5465721]^^^^Yup like everyone else said in that thread rims are way to big. Cars sitting way to high.
Anywho thought this was pretty schweeet:
[QUOTE]
that carboard cut out body is not what's up
Old Nov 8, 2010 | 10:01 PM
  #17225
Matzo Ball's Avatar
Funny, I was doing this calculation today, but using trig formulas. Yes, 1* is approx 5mm, depending on side wall height, you are closer to 5.3-5.5mm per 1*.
Old Nov 8, 2010 | 10:17 PM
  #17226
Matzo Ball's Avatar
Helping a friend out with his setup, looking for a definitive answer on this and I'm sure one of your guys can confirm.
X mm = 1 degree of camber
What is X? I've read 5mm all the way up to 10mm. If you go 5mm more agressive how much camber do you need to add so everything clears?
This is for 19s by the way.
Thanks guys!
pretty much, use a trig formula with a right angle triangle. I created a formula for you to use...
In this pic, visualize your wheel well. The angle is front the center point of your wheel. The angle (theta) will be the degree change in your camber setting. Side CB (adjacent side) will be your wheel + tire height. Side AB will be your clearance (opposite side)
remember: tan(angle theta) = opposite side(AB)/adjacent side(CB)
therefore: to figure out opposite side length (AB) you must have the following algabraic formula:
tan(angle theta) x adjacent side (CB) = opposite side (AB)
tan(theta)xCB = AB
theta = tan(1*) = .0175
CB = Sidewall height (mm) + (Wheel diameter in mm/2) {note 1in = 25.4mm)
AB = clearance (mm)
theta(CB) = AB
Here is what I ran for my car today. Running a 255/35/19 rear
Sidewall height = 255(.35) = 89.25mm
Wheel Diameter = 19"(25.4) = 482.6mm/2 = 241.3mm (radius)
CB = 89.25+241.3 = 330.5mm
.0175(330.55) = 5.78mm overall change in clearance from the fender line w/ a 1* change in camber (+ or -)
Old Nov 8, 2010 | 10:25 PM
  #17227
eurodre's Avatar
Apply today for your math degree from the University of G35Driver
Old Nov 8, 2010 | 10:30 PM
  #17228
Frankieg35's Avatar
Haha.. i need a refresher course..
Old Nov 8, 2010 | 10:32 PM
  #17229
Matzo Ball's Avatar
You can get your GED....General Edimincashun by Driver.
Old Nov 8, 2010 | 11:42 PM
  #17230
Dranom's Avatar
Hahaha! Good stuff!
Old Nov 8, 2010 | 11:46 PM
  #17231
ill Sedan
Dave you da man! Thanks for confirming with the math..haha
Old Nov 8, 2010 | 11:51 PM
  #17232
eurodre's Avatar
what about the rest of us that helped out?
Old Nov 8, 2010 | 11:53 PM
  #17233
ill Sedan
Eh, you just said 5mm, I kinda already knew that.
Now 5.78mm calculated via trig, that's some real info.
Old Nov 9, 2010 | 12:07 AM
  #17234
OCG35's Avatar
^^^ but who's gonna double check to make sure the calculations are accurate?
I presume it is accurate and with that - very impressive I've searched the internet for definitive and that's the most concise I've ever seen.
Old Nov 9, 2010 | 12:09 AM
  #17235
ill Sedan
Its been almost 13 years since I've taken trig, maybe one of these youngins on here can check Dave's math.
