Old Feb 7, 2011 | 07:37 PM
  #20551
Frankieg35's Avatar
Why can't u pull your fenders??
Old Feb 7, 2011 | 07:45 PM
  #20552
Adon's Avatar
because I fckin fail hard, I tried rolling my fenders like 2 years ago or somethin, couldn't do it so I whipped out the dremel and ended up cutting them. It was a good clean cut, but wrong ****in move if I wanted them pulled easily in the future.
Now when the shop tries to pull them, it comes out and then it folds right back in into it's normal position, the shop made a few passes on my rear left and you can barely see maybe got like 2 or 3 mm's out of it but that's about it, couldnt pull out any further.
The seam between the inner fender lining and the actual outer fender on the outside of the car has been severely compromised, and now I remember and it makes sense what the guys on here were telling me about when they said the structure is weaker now after cutting and might not hold up.
Old Feb 7, 2011 | 07:54 PM
  #20553
CandlestickPark's Avatar
ill Sedan
How much camber are you running, you may want to add a bit of negative camber so it doesn't rub so badly.
Old Feb 7, 2011 | 09:27 PM
  #20554
ill Sedan
Old Feb 7, 2011 | 09:56 PM
  #20555
GreenGoblin's Avatar
The goblin resurrection
Adon are you sure the suspension is setup correctly? What coils are you running again, are they true in the rear? Also any camber arms etc?
Old Feb 7, 2011 | 10:09 PM
  #20556
Frankieg35's Avatar
Yumm luv me some weds lxz!!!
Old Feb 7, 2011 | 10:22 PM
  #20557
NNOCENT's Avatar
someone tell donpisto stop buying all the rims i want on zilvia
Old Feb 7, 2011 | 10:33 PM
  #20558
The Stimulation's Avatar
Lol. I'm not buyin any wheels on zilvia. Just tryin to sell mine, haha.
Old Feb 7, 2011 | 10:34 PM
  #20559
ill Sedan
Oh my goooooooooooodnesssssss!!
Old Feb 7, 2011 | 10:54 PM
  #20560
Frankieg35's Avatar
Somebody needs to pick up those equips on zilvia!!
Old Feb 7, 2011 | 10:59 PM
  #20561
-miltdoggie-'s Avatar
Thanks Marcus!!!!, I was on my way to post it.
  #20562
parhamm1's Avatar
^They're now on my350... That guy cut and widened his fenders to fit those bad boys. Soooooo sick!
Old Feb 7, 2011 | 11:00 PM
  #20563
ill Sedan
You got it Milt! Can't wait to see the rest.
Old Feb 7, 2011 | 11:01 PM
  #20564
Frankieg35's Avatar
Damn that's sick!!
Old Feb 7, 2011 | 11:12 PM
  #20565
ill Sedan
Dre needs those Equips I'm jus sayin'...
18x10 (-30) / 18x12 (-20) : 5.5" front dish, 6.5" rear dish
