Old Mar 26, 2011 | 04:53 PM
  #22516
Phil DeVtec's Avatar
Originally Posted by erklep
how bad is the rubbing? thats where you need to be man. if its occasional rubbing, just deal with it because that looks killer
I concur. Just keep it.
Old Mar 26, 2011 | 05:22 PM
  #22517
eurodre's Avatar
adon you are doing something wrong or missing something, yes it will rub but not over EVERY dip.. set to full stiff, bend all the necessary corners, alignment (fix toe)
Old Mar 26, 2011 | 05:35 PM
  #22518
Adon's Avatar
yea i had set everything to full stiff and even got the optional 10k spring rates in the rear, fenders are pulled much as they can be, i think it's just the width and offset of the rear giving me fits, 12.5 with +5 offset and 285 tire.... i know this is something most fitment guys don't going for such wide tires, but i like the look of wide tires from the back so wanted to get the best of both worlds.....
gotta say i almost failed but after my alignment and they fixed everything, a lot of shlt was off due to my last two alignments where they didn't do shlt, left the caster and toe all alone and they were both way off..... fck now i'm rolling this low with minimal rubbing, check it...
gonna do a full photoshoot tomorrow night, so i'll post FINAL pics next week sometime.... FCK I'M SO GLAD IT'S ALL OVER, now i can just enjoy my car no more stressing out
Old Mar 26, 2011 | 05:39 PM
  #22519
eurodre's Avatar
yah the beefy tire is whats causing the rubbing, you wanted the tire now gotta handle the rub
in the meanwhile can't wait to see the full shoot
Old Mar 26, 2011 | 05:40 PM
  #22520
WLMNGTN310's Avatar
Originally Posted by iiiiiekoiiiii
Front needs moar low...
Moar please!
Old Mar 26, 2011 | 07:31 PM
  #22521
ShanesG's Avatar
^That's a joke right?? lol
Old Mar 26, 2011 | 07:33 PM
  #22522
CandlestickPark's Avatar
ill Sedan
That 37 Sedan is on H&R springs IIRC. Needs to be a lot lower.
Old Mar 26, 2011 | 07:42 PM
  #22523
status:one's Avatar
Adon - Dial in some camber and stretch the tire some more... aggressive wheels/stretch tires only look good when slammed... you gotta keep that height homie!
Old Mar 26, 2011 | 07:45 PM
  #22524
iiiiiekoiiiii's Avatar
Originally Posted by WLMNGTN310
Moar please!
Thats all till the pix come out later today. They did a photoshoot.
Joke?
And yes, its awd sedan with 37coupe H&R springs. No idea why fronts higher then the rear, usually H&Rs are even drop. We just wanted to see what offsets he can rock.
When the rims go on my car I will be a lot lower.
  #22525
ill Sedan
Good man!
Old Mar 26, 2011 | 07:49 PM
  #22526
Good man!
BC coils get low. + picked up oem front lip.
but stance on that 37 sedan is so sexy, especially rolling booty shots. There is 0 ground clearance with midpipes.
Old Mar 26, 2011 | 07:50 PM
  #22527
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Is that tape on your fender, Adon?
And you ever get your wheels fixed? Wheel faces look great. I really dig your new set up and I'm glad to see you finally start to finish up your stance. I know you had a lot of frustrations within the past few months with getting these to fit.
Old Mar 26, 2011 | 07:52 PM
  #22528
ill Sedan
Yeah I noticed that white duct tape too.
Old Mar 26, 2011 | 07:57 PM
  #22529
I just cant go that far man, lol
Flat roll, few mm pull no biggie, but fenders turning out like that is just pointless to me. Its all about keepin the sexy body lines, and bringing out the most you can and making the best fit possible. But everyone got their own point of view.
Old Mar 26, 2011 | 08:03 PM
  #22530
ShanesG's Avatar
Joke?
Yeah it doesn't belong in here, reverse rake + the entire front of it is just -__-.
