Old Jul 24, 2011 | 02:56 AM
  #26821
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Saw this at a meet tonight.
Old Jul 24, 2011 | 02:57 AM
  #26822
JBF's Avatar
JBF
doesn't Shane have 12 rears?
Old Jul 24, 2011 | 02:58 AM
  #26823
XiN's Avatar
XiN
Itasha Coupe
^^ I thought they were 11.5
Old Jul 24, 2011 | 03:02 AM
  #26824
i think they were 11.5, i believe he has 12s now, anyways, disconnected battery, lights still on.
Old Jul 24, 2011 | 03:49 AM
  #26825
Adon's Avatar
I got 12.5 rears with 285/30 tires and -5 camber, everything else in oem spec aside from camber..... and I did have a close call with VDC the other month, it was raining hard road was very wet, I was on a curve merging onto another road and VDC thingy kicked it, saw it flash on the dash and for some reason it felt like both my rear wheels locked up not sure, but whatever vdc did, ended up completely losing traction in the rear which put me in a drift.. Luckily i've done a bit of drifting here n there so i swung the car back to grip with ease...
This exact thing also happened to me few years back with my other wheels, but that was when my camber toe and all other settings were completely outta whack so i blamed it on that..
And im no expert on what vdc is and isnt supposed to do, but im pretty sure its not supposed to fckin lock up the rear wheels long enough to lose complete traction
Old Jul 24, 2011 | 04:09 AM
  #26826
Dranom's Avatar
Originally Posted by iseechriss
does running 11s in front throw off any codes? just installed mine and vdc slip and abs went on . im hoping i didnt hit the sensor when installing it.
It went on coz you didnt post pics!
Post some and it will go away
Old Jul 24, 2011 | 05:52 AM
  #26827
xXHotelCrazyXx's Avatar
Chris, leave it disconnected overnight then
Old Jul 24, 2011 | 05:57 AM
  #26828
Then when you reconnect, do ecu reset procedure
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” (NOT start) and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. If the CEL light continues to remain ON, repeat the above steps. Remember, timing is EXTREMELY critical to resetting the ECU. You may even need someone's help to do this correctly.
Old Jul 24, 2011 | 11:24 AM
  #26829
eurodre's Avatar
you kids are just nonsense in here, mine did the same when i drove it the first time and it wouldn't let me go past 3k rpm in 3rd gear
fix? i turned vdc off drove for 5 min, turned vdc back on and no more problem, I been driving her ever since
its that broscience but it done worked for me
Old Jul 24, 2011 | 12:23 PM
  #26830
DogStar's Avatar
kevins answer was the professor scientific method style
dres was the street shorthand version
Old Jul 24, 2011 | 12:42 PM
  #26831
Wicked_limitz's Avatar
couple shitty iphone pics of my buddy's Z posted a few pages ago and a sneak peak of the Z i just picked up 2 days ago.....
Old Jul 24, 2011 | 12:45 PM
  #26832
djfarhan's Avatar
^ like
Old Jul 24, 2011 | 12:47 PM
  #26833
eurodre's Avatar
that's not the only thing that's shitty
bahahahahhahah lmfao I had to, just bustin yo ***** man
Old Jul 24, 2011 | 12:58 PM
  #26834
O HELLA OEM's Avatar
i think the 350z would look cleaner without the cf hood
Old Jul 24, 2011 | 01:00 PM
  #26835
lol i see what you did there
