Old Nov 13, 2009 | 03:54 AM
  #6151
The Stimulation's Avatar
For my next setup I'm gonna either do 11's with a high single digit or low double digit negative offset or a 12 with a 0 offset....in the front
Fender work for sure, not gonna camber more, unless I'm able to get another degree, but the cost is probably not worth it. Already test fit my 10.5 +0 with 15mm spacers and it's not as bad as I thought it would be. Guess for the rears I'll have to step it up to a 13 with single digit negative offsets, or if I stick with 11's in the front, I'll go with 12's with double digit negative offsets Camber in rear will also decrease so it matches the fronts better, probably be at -6.
Hopefully I'll be able to sometime next year.
Old Nov 13, 2009 | 03:57 AM
  #6152
eurodre's Avatar
lol levon u r crazy, but question, any reason u want to go wider as opposed to same widths just smaller offsets? i mean the only change is the inner clearance, but requires more tire obviously
  #6153
evil350zdriver's Avatar
Originally Posted by ShanesG
kekeke
God dam!! to bad I cant make it to hellaflush this weekend to see the new setup..
So that means u should post more pics for me
Old Nov 13, 2009 | 04:03 AM
  #6154
I dunno lol. I guess cos I want wide *** wheels. Now that you mention it, I'll re-think just because of tire sizes. I'll go with something that allows me to stick with a 225/35 up front and 245/35 in the rear. So prob an 11 in the rear and 10 up front. Unless I step it up to a 265/30 or 265/35 for the rear, but then I'll go with a 12 in the rear for sure.
My goal is to break limits, but my main goal is to have an 8" lip (or at least 7") in the rear.
Old Nov 13, 2009 | 04:06 AM
  #6155
eurodre's Avatar
i ono about the 8" lip, well most wheel companies don't even make that so thats leave you with the expensive options, but lol that would be interesting
Old Nov 13, 2009 | 04:10 AM
  #6156
Yeah I know, but I figure if I'm gonna spend the money, might as well do it right. I know garson makes one close to an 8" lip (7.7"). Fug it, I'm shooting for an 8" lip, haha.
Old Nov 13, 2009 | 04:11 AM
  #6157
eurodre's Avatar
yah dude garson does do it, but isnt it like 4k per 2 wheels or some ****?
Old Nov 13, 2009 | 04:14 AM
  #6158
G37Rider92649's Avatar
Hey Shane!......HOLY SHIET FOOOO!
Old Nov 13, 2009 | 04:16 AM
  #6159
I dunno, quite expensive from Garson, that's why I'm not going with them lol. It's all thoughts right now, when it comes closer to actually doing it, then maybe reality will hit and I'll see what I can actually do dependent on cost.
Old Nov 13, 2009 | 04:17 AM
  #6160
ShanesG's Avatar
Thanks 2c, hope your **** gets figured out asap :/
But damn i neeed to get my new fronts rears make the fronts loook like bitch setup LMAO!!!
  #6161
eurodre's Avatar
ya fa sho
Old Nov 13, 2009 | 05:14 AM
  #6162
Dranom's Avatar
just gonna post here before going back to OEM 19s
fairview002.jpg?t=1258107154
Old Nov 13, 2009 | 11:14 AM
  #6163
OEM 19's for the wi..... wait, only if you have oem wheels on a sedan
Gonna miss your wheels, can't wait to see what you go with next.
Old Nov 13, 2009 | 05:22 PM
  #6164
w0ady's Avatar
fgc moderator
clean setup dranom.
Old Nov 13, 2009 | 05:43 PM
  #6165
Dranom's Avatar
Originally Posted by w0ady
clean setup dranom.
thank you sir
