The Demodding Begins
I used to use Beach Cities Powdercoating in Gardena on Rosecrans Ave. Most of the guys from R-Rides go there (caskyline, rookie, martyg35, etc.). Now I use Young Gunz Performance Coatings because they're 3 minutes from my home (Rancho Cucamonga). Just had some stuff done today. Will pick it up tomorrow.
Engine bay work is done. I'll bet I'm the first person on this board to have done and undone a wire tuck.
BEFORE DEMODDING:
AFTER DEMODDING:
EMBLEMS, TAILIGHTS, AND EXHAUST SWAPPED:
BEFORE DEMODDING:
AFTER DEMODDING:
It really depends on how thorough you want to be. If you want to sleeve all visible wires, it takes 40 or so labor hours. The sky is the limit. Look at engine bays like caskyline's and rookie's. SO MUCH DETAIL! Bet you can't look at a pic of their bays and point out all that's changed. The wire tuck is quite and undertaking. There are a lot of bad things that can happen as a result of doing it incorrectly.
