Got busy this weekend! - Shave and Roll
Needed to do some more tweaks on the G so I went to work Friday as soon as I got home from work. The first issue I had to fix was an uneven drop in the rear. The right settled about .5 inch higher than the left so I shaved the right spring mount. Almost thought of taking out the lower bump stop, but figured shaving was a better option than having metal to metal contact.
Next up was some fender work. I had some major rubbing going on, so needed to free up some more clearance.
Next was a trip to the alignment shop for some more adjustments. I knew it was a good sign when the guy spotted my 5zigen lugs as soon as I got out of the car.
Front: -2 camber
Rear: -3.9 camber
Almost there ... more work set up for next week
Front: -2 camber
Rear: -3.9 camber
That's some quality fender roll. Now you can even throw 10mm spacers in there. I hate to say it though, but 5zigen lug nuts are junk.
I had the same ones in blue and they strip so easily it's not even funny. The material they're made of is way too soft. They are good only for the first few times you take them off. But they sure do look good.
Originally Posted by accordfreak
was it hard cutting the spring mount? did you follow the DIY? i'm about to do mine.
BTW, big thanks for the fender roll DIY!
Originally Posted by cerr
nah, cutting the spring mount was not that hard. It's more of a PIA getting a straight cut because it is an awkward piece to deal with. Just don't forget the WD40, it makes life a lot easier.
nice! glad it helped.
i'll keep the wd40 in mind.
Originally Posted by SIN3
looking good man, spacers 10-15 rear and you can always go lower. shots of the whole car?
full shots to come after I get the spacers in.
why are you running so much neg camber in the rear? Your wheels should easily clear with that roll and less neg camber. Are you planning on installing 15mm spacers?
the car pulls a little to the left now, so i want to get this corrected. if anyone has a link to the instructions or copy of the cutting template this will help me convince them.
i do plan on putting spacers on soon ...
ps. thanks for the DIY
how did they install the toe bolts, did they put it on the end of the camber arm(common mistake)
http://turboneticsownersclub.com/tur...oltinstall.pdf
