Work Schwert SC1 Step Lip.
Originally Posted by Johnmikins
It should clear depending on how dropped you are, I needed the roll with my drop. Im running 20x10.5 +15 285/30/20...Camber kit going on in about a week!
Originally Posted by jlin615
I have the same wheel spec as you, except my tires are 275 and the drop is slightly higher than yours. With the camber kit, what degree you planning on adjusting your camber ? Are you still gonna clear?
Have no idea, but the guy that works on my suspension will make it perfect with no rubbing issues.
You mean Westend Ole'Skool Darin? I'm planning to go to him.
yoyoyo8
Aug 12, 2015 03:04 AM
ill bring a couple steaks
