Wide Tires.
Old Nov 13, 2008 | 04:03 AM
O HELLA JDM's Avatar
anything more than 295 on a 10.5 will be ehhh imo....
Old Nov 13, 2008 | 04:07 AM
Dem1K's Avatar
Originally Posted by Triple8Sol
Alot of it depends on the tire. For example, a 275/35/19 Michelin PS2, Advan Sport, RE050A will be as wide (if not wider) than a 285/35/19 Toyo T1R, Falken FK452, Goodyear F1 GS-D3.
Do you happen to know why that is? Just curious.
`John
P.S. Also, did they ever update the PS2 tires? I just picked up a pair and the sidewall is slightly different than my current tire.
Old Nov 13, 2008 | 04:12 AM
Triple8Sol's Avatar
Just because
Different manufacturers and models within the brand are just designed differently. Each tires is designed with a different sidewall thickness, sidewall height, sized contact patches, etc...
Old Nov 13, 2008 | 04:15 AM
Dem1K's Avatar
No I know, that I understand. You made it seem like it's a known fact that the PS2/Sport/RE050As are wider, so I didn't know if this was proven or not.
Old Nov 13, 2008 | 04:35 PM
Triple8Sol's Avatar
Proven by myself. I've personally owned and driven on almost all of the high-performance tires out there. I've tried many others, but these are the ones where there was a clear difference without needing to bust out a ruler.
Old Nov 13, 2008 | 04:44 PM
Dem1K's Avatar
Sweet, good to know, thanks
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
alexbenz
Sep 26, 2015 11:30 AM
