A couple updated pics of my LR G
Old Jan 29, 2009 | 03:07 AM
xXHotelCrazyXx's Avatar
Nice pics!
Old Jan 29, 2009 | 09:06 AM
mt7rabbit's Avatar
Originally Posted by sk8bo4rdv
looks hella siiiiick wat the size of ur rims??
front
9.5 x 20 - 255/30/20
rear
11 x 20 - 285/30/20
I am not a member of the secret squirrel offset society so I have no problem telling you that they are +15 offset all around.
I have minimal rubbing issues on the front mainly because I chose to go with such a wide tire. This only happens when I go over bumps or dips at over 35 MPH. My solution to this is installing a front adjustable camber arm and adding a tiny bit of negative camber, about -0.5 of a degree should do the trick.
Old Jan 29, 2009 | 12:08 PM
sk8bo4rdv's Avatar
Originally Posted by mt7rabbit
front
rear
11 x 20 - 285/30/20
hahaha much appreciated bro. and the secret offset socity is freakin retarted. more props to u for not bieng part of the "club" haah
Old Jan 29, 2009 | 12:09 PM
Wicked_limitz's Avatar
any side shots?
Old Jan 29, 2009 | 12:33 PM
Johnmikins's Avatar
Very clean!
Old Jan 29, 2009 | 12:35 PM
twin001's Avatar
Very nice!
Secret Squirrel Offset Society! It's sad, but true.
Old Feb 5, 2009 | 09:57 AM
mt7rabbit's Avatar
Originally Posted by Wicked_limitz
any side shots?
Here is a side pic, my camera is a little outdated, even with full exposure this is the best I could do, so I made the background black and white for more contrast.
Old Feb 5, 2009 | 10:16 AM
G35Ian's Avatar
nice ride!
Old Feb 5, 2009 | 12:38 PM
escobar929's Avatar
your G looks amazing!
06 headlights will def make it look so much better
Old Feb 5, 2009 | 01:56 PM
ATL_Red_G35's Avatar
Very nice combo, I like how nice and clean the car looks.
Old Feb 5, 2009 | 06:26 PM
tiguy99's Avatar
Originally Posted by Red_G35
looks good
needs mt fuji
+1 like in a black chrome to match the grill and/or wheels
Old Feb 5, 2009 | 07:36 PM
noize's Avatar
Looks real good with nice offset. I wish it was a tad lower though. It would look sick then.
Old Feb 6, 2009 | 09:17 AM
mt7rabbit's Avatar
^I want to lower it more but then I would not be able to get up my steep driveway, not to mention the place I work at has speed bumps that I can barely get over as it is. The only option would be to get air suspension and drop it some more.
Not a bad idea, I might consider that thanks.
Old Feb 9, 2009 | 11:19 AM
mt7rabbit's Avatar
I finally had some time this past weekend to paint the grill. The process was simple but took lots of patience. I sanded the original color off then applied a few coats of primer. I sanded again to a smooth finish, and applied two coats of paint, sanded again. Finally two last coats of paint and a clear coat to protect it all. The removal and installation of the grill was very easy.
The last pic was taken on my steep driveway so the gap between the front tires and fenders are actually less. I'm thinking next month maybe I'll paint the headlights to match.
Old Feb 9, 2009 | 11:25 AM
  #30
str3ryderz's Avatar
very nice
skippyG
Jan 25, 2016 01:18 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
Frostbite91
Aug 20, 2015 07:20 PM
tiguy99
Jul 26, 2015 01:39 PM
