red G
how big of spacers you think? i really would hate to have to chop the stock studs cause these are only temps, last minute kinda thing, better then stock wheels tho. any input to make the ride better is much appreciated!
i have the same coils. did you set them to as low as possible or do you still have some room to go lower?
and i thought you said you wanted them stiffer? then you asked what to do for a better ride, those are opposites...
better the car not the actual ride.. it drives fine.
no lower unless i start pulling perches off the sleeve, which i have done before, but this is low enough for this car mos def.
trying find for someone to do the alignment on this bitch is impossssssssssible!
