dual trunk led boards
i didn't like having just one led board in the middle. i wanted one board for each sub. so i spliced some wires, tucked them behind the trunk liner, and bam.
the right side looks brighter because it was pointing down. i fixed that after i took the pics.
^^^you have to duck down pretty low to notice that the center dome is empty.
i also replaced the license plate lights with two led boards. some of you may argue that you don't want the plates lit up well. doesn't really matter because if someone wants to read your lights he's going to shine his headlights at you anyway lol
i've gone through a LOT of LEDs in my short time. every time prior to these i've been left wanting more. whether it was brightness or whiter light, i never got it until i picked these up. you can buy them from henry at statik.
https://g35driver.com/forums/accesso...plate-led.html
nice cal, you're on a roll with all the little mods lately. ive seen these but waiting on someone to post output pics. ive got superbrightled cool/white all around my car. they match my 6000k lights perfect but if i ever went brighter, id check these out.
haha your just like me i went all out on my led's as well :
i love how the plate illuminates, are you using the 6led board on your trunk? i was thinking about putting a 36 but i think it a little too much
i'm using the 6 led boards in every the domes, doors, trunk, and license plate lights. i spliced some wires and fit two boards in my trunk, one for each sub. i didn't like the way one light looked in the center.
This thread inspired me to go out and buy some from Henry. Great guy to do business with.
One thing i didn't like about the domes is that i couldn't find a good place to mount them to point straight down and it didn't feel secure enough if i had just kinda left them half sticking to part of the plastics. Instead i used a 4x4 cube lego and used additional 3M tape to stick it into the light and mounted the 6 LED board on the brick. Now each side points straight down and is nicely centered inside the dome. Worked out great.
Calvin already asked for pics, so i'll get those up later.
Here are the pics of how i incorporated the use of LEGO for the LED's
(please excuse my lack of photography skills. I'm not Calvin
The trunk - I used a LEGO Brick here too, but it was impossible to get a shot of it. If you look at the trunk dome, there's an area right in front of the dome that's bare metal. I just stuck the brick there and put the LED on it so that it clears the carpeted area:
You can see how i stuck the LEGO brick in to prop up the LED panel:
LED Boards are centered inside the housing. It makes a HUGE difference when the dome lenses are back on and the lights are on:
Another shot:
The LEGO piece i used:
(excuse the dog hair)
)The trunk - I used a LEGO Brick here too, but it was impossible to get a shot of it. If you look at the trunk dome, there's an area right in front of the dome that's bare metal. I just stuck the brick there and put the LED on it so that it clears the carpeted area:
Another shot:
^^^yah i looked up your trunk last week and thought about doing the same, but decided to go this route. nice trunk setup tho.
i'm going to open up my license plate light housings and do the same with bigger boards. $300 from clearcorners is just too much for what it is. the boards cost like $20 each at most. gonna open them up this weekend
