The Greengoblin build thread
Old May 8, 2010 | 09:46 AM
  #511
Locksmith's Avatar
Baller status
Old May 8, 2010 | 06:12 PM
  #512
GreenGoblin's Avatar
The goblin resurrection
oem vs SPL v2
Close up
Had to grind the casting bumps down
Misc install pics
Old May 8, 2010 | 06:43 PM
  #513
Glex25's Avatar
Administrator
Very nice Danny
Those SPL ver2 arms look so beefy
They are the
Old May 8, 2010 | 09:54 PM
  #514
Ya so much more beefy than stock. I can't wait to fine tune the suspension once the car is on the road.
Old May 8, 2010 | 10:01 PM
  #515
antknee's Avatar
ha sweet coilsssssss! i got the same thing! for 2 months now but i havent installed it yet fml
Old May 8, 2010 | 10:06 PM
  #516
Ive had mine about 8 months and drove zero miles on them
Old May 8, 2010 | 10:30 PM
  #517
Matzo Ball's Avatar
time to clean up those rotors.
Old May 8, 2010 | 10:33 PM
  #518
Adon's Avatar
hey Goblin just a quick question about the OEM wheel studs seen in the picture below. Are you planning on replacing them ? I've read a few bad things about OEM studs and basically what I got from it that it's a good idea to replace them with Nismo or ARP studs.
I have been running wheel spacers for about 30k now I imagine they are probably stressed out by now. Since I'm about to put my new wheels on, I would like a fresh set of studs, so what would you recommend and where can I get some ?
I've heard talk of ARP studs but can't find them anywhere, then I seen the Nismo studs for sale but only the extended ones.
and hey are those paint chips on your calipers from your wheels spokes rubbing them ?
Originally Posted by GreenGoblin
Old May 8, 2010 | 10:42 PM
  #519
SDGeneralCounsel's Avatar
Pretty lol. Looks like you need the RA rotors to replace those lol.
Old May 9, 2010 | 01:18 AM
  #520
elperuano's Avatar
RA rotors?...... *facepalm*
Old May 9, 2010 | 08:25 AM
  #521
Glex25's Avatar
Administrator
Don't mind the RA nuthugger
He has to put his .02 into everything
and it's usually wrong anyways
Old May 9, 2010 | 08:57 AM
  #522
The studs I am running are not stock they are Nismo extended. So no I am not planning on replacing them as its only surface rust from letting the car sit outside for months. You can get stock replacements, nismo, H&R, ARP etc they are all available just depends on what you want. There is a scratch in the paint on the driverside caliper when I was running the ccw wheels a rock made it up in between the caliper and back of the rim... oh well maybe someone will setup and let me show off there bbk.
Unless they want to send me a set, I am not paying that much for the rotors, these are fine just need to go for a ride to clean the rust off.
Old May 9, 2010 | 01:24 PM
  #523
drsifu1's Avatar
Staff ALUMNI
20 Year Member
^i wouldn't even bother putting them on even if they were free.
your brakes will keep you alive. no reason to put a POS rotor on it and wonder every time you tap your brake whether or not it will be your last.
Old May 9, 2010 | 02:30 PM
  #524
Very true, I totally agree and would not buy or support anything from RA
Old May 9, 2010 | 02:33 PM
  #525
Adon's Avatar
thanks, 'ppreciate it. I'll look a little harder then I've been over the marketplace both here and my350 but haven't found vendors selling studs, or maybe they are but just not listing it in the thread title because it's such a small item.
one more quick question, the OEM studs are 42mm correct ? ? I checked myNismo.com and they sell the 50mm and 60mm studs only
You have already rated this thread Rating: Thread Rating: 13 votes, 5.00 average.
