The Greengoblin build thread
Old Oct 8, 2010 | 11:24 AM
  #1321
erklep's Avatar
got one of those electric superchargers didnt you?? i knew they worked!
Old Oct 8, 2010 | 04:56 PM
  #1322
GreenGoblin's Avatar
The goblin resurrection
They arrived...
Old Oct 8, 2010 | 04:57 PM
  #1323
Matzo Ball's Avatar
wow, red X's make you go fast!!!!!
Old Oct 8, 2010 | 05:00 PM
  #1324
erklep's Avatar
crower cams im guessing?
Old Oct 8, 2010 | 05:06 PM
  #1325
^ winner.
Brian Crower BC 350Z/G35 VQ35DE cams are a great upgrade for drivers who want an increase in power, without a loss in around town drive ability. These cams are designed to drop right into your existing valvetrain without any modifications or additional components required. Dyno proven to improve HP through mid to high RPM range. The cams will have mild lope at idle. Overall great upgrade for street use. OEM springs will work with these cams.
Stage 2 Specs:
Adv. duration: 264 in / 264 ex
Dur @ 0.050 : 222 in/ 222 ex
Lift (in) : 0.426"/ 0.426"
Lift (mm): 10.82/ 10.82
Old Oct 8, 2010 | 05:07 PM
  #1326
TIAN's Avatar
Hold The Line
So what are we talking about as far as gains? FI vs NA?
Old Oct 8, 2010 | 05:16 PM
  #1327
I am not sure but power with not fall off around 6.5k like the stock cams.
Old Oct 9, 2010 | 12:22 AM
  #1328
Windshield is in.
All the interior pieces painted
Passenger seat is in.
Old Oct 9, 2010 | 12:24 AM
  #1329
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Cac damn i love your car!!
Old Oct 9, 2010 | 12:28 AM
  #1330
JOKER's Avatar
CLUB MODERATOR
what did you use to put in your windshield (process and materials)?
Could you put in a quarter panel window the same way?
Old Oct 9, 2010 | 12:52 AM
  #1331
Thank you.
Put the seal on the glass and a bead of the windshield glue around the lip, set the glass in and push it down. It would be similar, but the quarter glass has clips so glue and push the clips in.
Old Oct 9, 2010 | 01:04 AM
  #1332
Glex25's Avatar
Administrator
Nice progress Dan
When are the cams going in?
Old Oct 9, 2010 | 01:08 AM
  #1333
JOKER's Avatar
CLUB MODERATOR
Originally Posted by GreenGoblin
Thank you.
any specific brand of glue?
Old Oct 11, 2010 | 08:07 AM
  #1334
Originally Posted by Glex25
Nice progress Dan
Maybe 2 weeks or so when I get a full free weekend.
Something like this is from 3m its a windshield urethane.
http://www.autobodytoolmart.com/3m-a...3-p-15923.aspx
Old Oct 13, 2010 | 03:09 PM
  #1335
nyqueenz's Avatar
^ winner.
Stage 2 Specs:
I guess thats the only corner i cut with my build was the bigger Cams.. i guess if i decided to do an angle job on my heads next time.. i will go wit the BC.
You have already rated this thread Rating: Thread Rating: 13 votes, 5.00 average.
