Heist's BMW 2002 build
Old Jun 4, 2011 | 11:58 PM
  #76
HwyDrftr's Avatar
Originally Posted by Heist.
SO I think I'm just going to go with molding in fender flares and running the 17"'s as low as possible.
Do it!
Old Jun 6, 2011 | 02:03 PM
  #77
Heist.'s Avatar
So I took 2 days away from this to give me a solid amount of time to think of a solution. I'm going to try to fit the 17's with some 35's and get it as low as possible. I did some measurements and it should be perfect with about 2-3" of ground clearance once its all dropped down. Exactly what I wanted not dumpt, but clean and fun daily. So the plan:
I took measurements of the fender flares and how much of the metal under them I can cut away. I did this because I can try building metal flares off the preexisting metal... if it sucks i'm just going to cut it away and mold in plastic/fiberglass flares. I can't find any real good information on forming my own fender flares so I came up with this
(the inside lines will be cut away for the fender flares so I have some room to play)
With any good theory it gets followed by ghetto card board cut outs so I feel better about my silly ideas
seems possible...kinda.
I want it to be like the e30 stock fenders. Just worried it will be a wavy park bench...
Old Jun 6, 2011 | 03:26 PM
  #78
Matzo Ball's Avatar
it you use enough bondo or weld additional metal to the cut fender wall, you would be able to grind/sand it down for a smooth surface. status : one did something similar for his metal widebody I think.
Old Jun 6, 2011 | 03:52 PM
  #79
Heist.'s Avatar
ok this should be interesting cant wait to get the tires off the wheels and do some proper test fitting and measurements.
Old Jun 6, 2011 | 04:42 PM
  #80
G35SedanGrn's Avatar
what are u gunna do about the wheels hitting parts of ur susp?
Old Jun 6, 2011 | 05:06 PM
  #81
Heist.'s Avatar
tiny spacer in the back and it clears because the negative camber follows the slope of the spring. Same for the front I have adjustable camber plates for the front which will pull the spring towards the car allowing for a few mms of space I need. I HOPE
Old Jun 6, 2011 | 05:10 PM
  #82
Hopefully it works out for you, should look sick when it's all said & done...why not go full widebody?
Old Jun 7, 2011 | 12:06 AM
  #83
Heist.'s Avatar
Should I cut the flat arch off first and weld it on? what do you guys think?
Old Jun 7, 2011 | 11:08 PM
  #84
Heist.'s Avatar
I have no clue what I'm doing.... but.....
Old Jun 7, 2011 | 11:21 PM
  #85
looks good. maybe a tiny bit wider would have been better but looks a lot better than i was expecting haha
Old Jun 8, 2011 | 12:12 AM
  #86
HwyDrftr's Avatar
Hmm, was looking pretty good till the fender disappeared
Old Jun 8, 2011 | 12:42 AM
  #87
Heist.'s Avatar
I hope the negative camber will tuck it in just enough. I can always do a light pull later.
Old Jun 8, 2011 | 01:21 AM
  #88
Dranom's Avatar
does the car have camber kits?
looking good so far
Old Jun 8, 2011 | 02:02 AM
  #89
prinny's Avatar
You're crazy haha, but should look pretty legit if it all pulls through!
Old Jun 8, 2011 | 04:05 AM
  #90
JBF's Avatar
JBF
insane build dude. Can't wait for moar!
