Mechanical work in SD
Old Sep 2, 2011 | 12:21 AM
  #316
SDGenius's Avatar
SERIOUSLY... Thank You Grant, you've saved me a lot of time, money and sweat. You Sir are The Man!
Old Sep 2, 2011 | 12:50 AM
  #317
Gdup35sedan's Avatar
ENVautoDetailing.com
My pleasure Mark! Glad I can say I installed the first ever Umbrella VRH system on a G
Old Sep 2, 2011 | 12:53 AM
  #318
SDGenius's Avatar
w/o instructions either, LOL
Old Sep 4, 2011 | 03:16 PM
  #319
SDGenius's Avatar
https://g35driver.com/forums/g35-cou...san-diego.html
Old Sep 9, 2011 | 11:14 AM
  #320
SDGenius's Avatar
Grant, what do you think about solid rear diff bushings? might be picking some up
Old Sep 19, 2011 | 05:11 PM
  #321
SDGenius's Avatar
okay, i ended up picking up some Whiteline poly diff bushings instead. when you wanna install them? LOL
Old Sep 19, 2011 | 05:23 PM
  #322
Did you get the full kit or just the front?
Old Sep 19, 2011 | 05:30 PM
  #323
SDGenius's Avatar
full kit
Old Sep 25, 2011 | 04:31 PM
  #324
Jairen's Avatar
Grant, need a set of headers and cams installed once I find a set. LOL!
Old Oct 15, 2011 | 01:01 AM
  #325
Bump! Anyone need work done tomorrow? I'm off work at 2pm and I don't go back until thursday!
Old Oct 25, 2011 | 01:37 AM
  #326
WuNSiKG's Avatar
anyone know what might be the cause of rear bearing going bad after changing just a few months back? on my 2rd one now and dont know the reason why my bearings keeps squeaking? need any recommendations how to solve this.
Old Oct 25, 2011 | 10:08 AM
  #327
^^ did you replace it with an OEM wheel bearing or an aftermarket OEM replacement from a parts store?
Old Oct 25, 2011 | 01:24 PM
  #328
G35pm's Avatar
Alignment?
Old Oct 25, 2011 | 01:48 PM
  #329
importroller's Avatar
I need an alignment shop that can do a true 4 wheel alignment on a lowered car. Not Firestone, they only do Thrust alignments which will go out of specs after a few months of driving. I may have to take it to True Align in Santee/El Cajon for it to be done.
Old Oct 25, 2011 | 04:52 PM
  #330
Depends on which Firestone you take it to and what model rack/machine they have. When I was working at Firestone I did Calvin's alignment a good 6 times over 2 years (had to do adjustments after lowering and raising and sometimes check it just to make sure) The only measurement that was out every time was the front toe (which gets knocked out by normal driving over time)
