New G35 owner
Old Jul 27, 2011 | 03:19 PM
chanes5's Avatar
New G35 owner
Hey i just got my G35 about two months ago. Its a 05' 6speed MT coupe. I am approaching my 60k service and was wondering if there was anyone that could give me some info on the stuff i will need.
Old Jul 27, 2011 | 03:36 PM
sukh79's Avatar
cabin filter do it yourself, fluids...talk to seymore4 on here...he'll hook you up...otherwise just check your belts and brakes and see where they at.and welcome to the family.
sukh79's Avatar
+1 ...check your spark plugs also...make sure there's no oil in the tubes
Old Jul 27, 2011 | 04:05 PM
faiz23's Avatar
Hopefully your car has powertrain warranty. I would have an OIL CONSUMPTION testing done at the dealer and have your valve covers checked for leaks. Both are common issues with your vehicle and the OC is a major issue with revup motors which you have.
https://g35driver.com/forums/attachm...itb08-002c.pdf
https://g35driver.com/forums/g35-cou...rranty-up.html
https://g35driver.com/forums/tsb-tec...ption-tsb.html
Old Jul 28, 2011 | 08:48 PM
seymore4's Avatar
m56
Probably not gonna have warranty on an 05, unless you purchased an extended warranty through the dealer. I'd definitely recommend changing all the fluids and spark plugs ASAP. Our cars are notorious for destroying spark plugs before they're tuned, and you can gain around 3whp just from changing out to new plugs. When you do change them like faiz23 said check for oil in the spark plug tubes, mainly the passenger side. If its leaking you'll have to replace the valve covers... not cheap or easy.
Anyways welcome to the club and let us know if there's anything you need or got questions about!
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
Chattzx
Jul 17, 2015 11:23 AM
