SFL G CLUB South Florida G35's + G37's
Help!
Old Mar 28, 2008 | 02:37 PM
Nikki473's Avatar
Help!
Can someone please tell me what to do about the damm squeeky noise that comes from my brakes. Even though i dont need them!
Old Mar 28, 2008 | 03:04 PM
MikeYo's Avatar
mine squeak all the time, more in when i go in reverse that foward... nobody can specificly diagnose it.. ive had my rotors cut, and replaced and my pads as well and it still persists
Old Mar 28, 2008 | 03:14 PM
GreenGoblin's Avatar
The goblin resurrection
have you tried break clean ( do not do with wheels on)
Old Mar 28, 2008 | 04:54 PM
DiamondGCoupe's Avatar
LOL just spray some water in there that should do the trick, unless your breaks are low, then they are designed to be annoying so you will replace them.
Old Mar 28, 2008 | 09:00 PM
rpm06g35's Avatar
hmm you got me on this one
Old Mar 28, 2008 | 09:10 PM
MADMAXSS's Avatar
Everyone So Far Has A Point Unless Theres Plenty Of Pad And Maybe It Needs That Goo Thats Called Break Quiet Or Something Like That. That They Sell At The Counter At Advance Auto For Like 99cents. That Goes Between The Pads And The Shims/shim Kit. I've Changed Various Brakes Except Haven't Had The Need To Do It On The G Yet.
Old Mar 28, 2008 | 10:05 PM
DrrSeuss's Avatar
my brembos squeak once they warm up. I've tried taking out the pads and reapplying grease and the squeak always comes back..oh well..I've learned to deal w/ it.
Old Mar 29, 2008 | 11:33 AM
escobar929's Avatar
check the pads, they might be low
if not, then some Disc Brake Quiet should do the trick or any type of white lithium grease would do the job
Old Mar 29, 2008 | 12:01 PM
UltimateGee27's Avatar
you dont need them?
everyone needs brakes
Old Mar 29, 2008 | 12:06 PM
beachygirl's Avatar
Me, too. Just got an '04 with Brembos. High pitch squeel coming from right front brake is driving me INSANE ! Pads don't need replacing but I worry about rotor damage. Any suggestions would seriously be appreciated. Also, anyone know of a trustworthy mechanic in Orlando ? New to G35driver site- thanks
Old Mar 29, 2008 | 12:39 PM
G35SHAWN's Avatar
Old Mar 29, 2008 | 02:30 PM
escobar929's Avatar
most brembos squeel, the best solutions is to change pads
goto Performance Factory, they'll hook you up.
they are off of OBT and the turnpike
Old Mar 29, 2008 | 02:56 PM
Finiti35's Avatar
FGC South Florida BOD
Brakes will squeal depending on the metallic content of the pad you're running. Before you go off spending money on new brakes, do this:
1. Clean your rotors with a brake cleaner and/or scotch brite them to get rid of any deposits
2. Can't believe no one has said it, but bed in the pads. That's most likely the cause of your problem. Follow the instructions in the link below:
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Mar 29, 2008 | 03:54 PM
nin9919's Avatar
^^ + 1 on bedding... and also make sure your lug nuts are torqued at 85 pounds
