mod day
What do you mean pull them again. What I have so far is Tein S-Techs, Kinetix Rear Camber kit, Stillen Sway Bars, GTSpec Chassis Bars and now I'm getting D-Spec shocks.
If you want to just set the dampner on stiff and leave them then you're ok. If you want the ability to adjust them without removing them, you will need extension adjusters before the install.
Here's a link to the install. This is the set up I had with the D-Specs.
I know Stillen sells them and I think the cost is about $30. Most retailers that carry D-Specs will carry the extension.
https://g35driver.com/forums/brakes-...35-coupes.html
Cool, good looking out Boston. Thank you very much for your help. I just ordered some because you never know, i might change my mind about how stiff i want the shocks.
