SFL G CLUB South Florida G35's + G37's
Need Help installing Micro DE fog lamps!
Old Jan 14, 2009 | 01:17 AM
baseball23's Avatar
Hey im not too great with the lights and electronics.
And I am having a lil trouble finding a good DIY on here with installing fog lamps behind the lower air ducts behind the mesh, so if anyone knows of one i would realy appreciate a link to it. Or if you have some know how on this subject to maybe explain a lil.
Thx!
Old Jan 14, 2009 | 07:51 AM
escobar929's Avatar
im sure someone can, shouldnt be too hard
Old Jan 14, 2009 | 10:27 AM
GreenGoblin's Avatar
The goblin resurrection
should be a simple relay, you need to tap 12v+ and - which can be from you head light harness. I would suggest you install it so that they turn on when your stock fogs turn on.
Old Jan 15, 2009 | 02:08 AM
baseball23's Avatar
ok im realy not good with lights and stuff on my G. I need to know how to mount and take the bumper of and wiring and such (haha step by step instructonsP...noone has a DIY on here? I coudnt find one on this site...If you have seen one somewhere else i would realy appriciate a link to it or copy and email it to me if i have to have a log in to see it.
Old Jan 15, 2009 | 02:09 AM
gizmo134's Avatar
i didnt do a DIY, but i did put them in. do you need help more with the wiring or mounting?
Old Jan 15, 2009 | 10:25 PM
baseball23's Avatar
def more with the wiring, but just like a general out line on where and how to mount the lamps.
Haha wher eis Socorro? Is that where you are right now? not in FLA?
Old Jan 16, 2009 | 12:28 AM
gizmo134's Avatar
nahh, i wish i was in FL, im in NY right now and its freaking 17 degrees outside. brrr....
but yeah, when i have it back ill try to take some pics of the mounting. i basically got self-tapping screws and put them into the aluminum bumper support. i hid the wires between them, then put a relay in the brake box area, so theres just a signal wire from in the car. (recommend this highly, idiot me slightly melted my fuse box... )
as to what to use to switch them on and off though, its up to you. i built a small circuit, so i have two switches. one is on/off, and the other is IGN/Off. "DRL" of a sort haha
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Tylerttn
Jul 16, 2015 10:33 AM
attarday
Jul 15, 2015 04:03 PM
