SFL G CLUB South Florida G35's + G37's
outside the box
Old Mar 10, 2009 | 04:25 PM
rpm06g35's Avatar
outside the box
Just wondering what the interest would be if I were to make some spring cups out of aluminum instead of cutting your own cup(spring cup mod). I have actually come across some super dense plastic material to go between the spring and the cup. Let me know. Mike
Old Mar 10, 2009 | 04:46 PM
MastaRip's Avatar
Whats this for?
Old Mar 10, 2009 | 05:17 PM
nghiars's Avatar
Originally Posted by MastaRip
Whats this for?
instead of cutting the spring mount to get an even drop, he will manufacture spring mounts that are the dimensions of a cut one.
sounds like a good idea.
Old Mar 10, 2009 | 05:32 PM
rpm06g35's Avatar
true this way you can keep the factory ones.
Old Mar 10, 2009 | 09:42 PM
escobar929's Avatar
good idea mike, let us know the progress
Old Mar 10, 2009 | 10:52 PM
MastaRip's Avatar
oh i see, sounds cool.
Old Mar 10, 2009 | 11:00 PM
tucked_g35's Avatar
mike i am about to do the springmountmod to get about .5 inch more drop in the back. how do u plan on doing this???
Old Mar 10, 2009 | 11:02 PM
tucked_g35's Avatar
btw mike, it's george with the dg coupe from the starbucks meets.
Old Mar 11, 2009 | 04:04 PM
rpm06g35's Avatar
All my stuff is hard to explain bro. Its almost better if I do pictures while making them I'll post some up soon. Later mike
Old Mar 11, 2009 | 04:42 PM
iamericgee's Avatar
thats a good idea because i want to do the same thing !
Old Mar 11, 2009 | 05:32 PM
nghiars's Avatar
this will allow owners to bring their cars back to stock without purchasing rear spring mounts...
Old Mar 11, 2009 | 07:18 PM
TIAN's Avatar
Hold The Line
Sounds like a great idea. Mike, I suggest you become a sponsor so you can circulate more interest in the products that you fabricate and have more resources available as a vendor. Just a thought
Old Mar 11, 2009 | 08:14 PM
tucked_g35's Avatar
mike i will wait until you figure it out. but i suppose we will need to tell how how much of a drop we are looking for. it would be cool of you could make a base cup and .10" shims for adjustability.
Old Mar 11, 2009 | 09:27 PM
rpm06g35's Avatar
Shims would be a cool idea but I would rather just make them the size you need. Here are some pics from the start. I basically took stock aluminum and lathed it down to basically retain the spring. I will figure out the diameter of the base and the thickness of the cup. After the last cuts I will sandblast them to give them the finish coat.
<a href="http://s216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/?action=view&current=mjmotorsportsspacer001.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/mjmotorsportsspacer001.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/?action=view&current=mjmotorsportsspacer002.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/mjmotorsportsspacer002.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/?action=view&current=mjmotorsportsspacer003.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/mjmotorsportsspacer003.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/?action=view&current=mjmotorsportsspacer008.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/mjmotorsportsspacer008.jpg" border="0" alt="Photobucket"></a>
<a href="http://s216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/?action=view&current=mjmotorsportsspacer007.jpg" target="_blank"><img src="http://i216.photobucket.com/albums/cc243/rpm97talon/mj%20motorsports%20spacers/mjmotorsportsspacer007.jpg" border="0" alt="Photobucket"></a>
Old Mar 11, 2009 | 10:20 PM
tucked_g35's Avatar
so mike, you'd be replacing this:
with a 2 peice setup which consists of a hard dense plastic sandwhiched in between your aluminum cup design and the spring, correct?
