SFL G CLUB South Florida G35's + G37's
Broke my G =(
Old Apr 18, 2009 | 02:57 PM
CLiX`G35's Avatar
Broke my G =(
So i kinda spun out and went backwards into a median and my rear wheel is now sideways.... body damage is really just the mudguard.... but i need the bar that goes from the differential to the wheel.
I really don't want to go through insurance since some guy took a light last year hit me lied about it and no one was at fault...
ill post pics now.
Old Apr 19, 2009 | 09:39 AM
GreenGoblin's Avatar
The goblin resurrection
you might have more damage then you think, I would say at lease the toe bar and camber bar are toast
Old Apr 19, 2009 | 10:41 AM
w0ady's Avatar
fgc moderator
wow hope you're ok at least. and ya thats a lot of damage...
Old Apr 20, 2009 | 10:00 AM
CLiX`G35's Avatar
ok so i got in there and saw what the actual damage is .....
THe picture below is not mine i am using is as refrence but both the black and silver suspension links in that picture i busted..
MILLION THANKS to Mike who was nice enough to get me a set of suspension links yesterday.
I still need the silver one which is the link that runs from behind the caliper towards the front of the car.
Anyone know any good parts places that might have this in stock?
Old Apr 20, 2009 | 10:02 AM
g35man04's Avatar
CLUB MODERATOR
Those are the Stock Camber and Toe Arms..what you have pictured is all aftermarket parts. I have a set sitting in my garage...
Old Apr 20, 2009 | 10:08 AM
g35man04's Avatar
CLUB MODERATOR
also I dont know if that is the only thing wrong if your wheel is bent sideways...your axles could be out of wack as well...warped rotor...alot of that can only be seen if its really damage...the axle part you shoudl notice fairly quick but you will def need an alignment after re-installing them.
Old Apr 20, 2009 | 10:12 AM
CLiX`G35's Avatar
wasnt that bad ... wheel is just really scratched up either way i had a spare oem 19... I know those are aftermarket but it was the best pic i found.
What i am looking for is some place in Miami that might have them in stock.
Old Apr 20, 2009 | 10:19 AM
g35man04's Avatar
CLUB MODERATOR
yeah If I were you I would either go ahead and go aftermarket if you plan on lowering the car...I think they would be fairly expensive from a dealer for an OEM Part like that..I have them both sitting in my garage since I have changed all the OEM Suspension parts on my car.
Is this better:
Old Apr 20, 2009 | 10:24 AM
w0ady's Avatar
fgc moderator
ya rear camber stuff is way cheaper than fronts. might as well go aftermarket like they said. probably about $200.
Old Apr 20, 2009 | 10:51 AM
g35man04's Avatar
CLUB MODERATOR
here you go...quick check in Vendor Classifieds:
Rear Camber Arms: Nissan 350z/Infiniti G35 ALL (SKU 72050) $179 SHIPPED
http://thmotorsports.com/spc-perform...0/i-68855.aspx
Or Megan Racing:
Camber Arms:
http://www.robearracing.com/pd_megan...camber_toe.cfm
Toe Arms:
http://www.frsport.com/Megan-6335-Ra...E_p_13034.html
Old Apr 20, 2009 | 11:12 AM
escobar929's Avatar
sux man, hope it just the camber arms
Old Apr 20, 2009 | 11:16 AM
CLiX`G35's Avatar
No it was the camber and toe arms as well as the seal on the cv joint boot.
I already have the camber arm thanks to Mike.
I need a Toe arm and the seal. I called around and i can get the toe arm for $70 dollars at south motors but no one has the seal it would be special order and take three days.... luckly its only 12 dollars.
I will take pics of the broken arm and the repairs as i do them today.
Old Apr 20, 2009 | 02:11 PM
MastaRip's Avatar
Sucks, hope its all back to normal asap
Old May 10, 2009 | 11:34 AM
CLiX`G35's Avatar
well i got my car back ... turns out i needed:
upper control arm
Lower control arm
Knuckle
Camber and Toe arms
and CV joint boot resealed.
+ new rim
.............. sucked but I got shop price on the parts and only paid $350 for labor.
Im back driver again... =)
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
thewarden
Aug 30, 2015 04:00 PM
Crappyday
Jul 28, 2015 04:07 PM
newg37
Jul 26, 2015 09:32 AM
