Question about FI, specifically Boosted Performances kit
Feb 21, 2011 | 11:28 PM
But that is all under hood. What if we expanded elsewhere in the vehicle? Crazy G has his somewhere off beat too
Reply 0
Feb 22, 2011 | 08:54 AM
Quote:
e60 M5?
Reply 0
Feb 22, 2011 | 09:16 AM
Quote: But that is all under hood. What if we expanded elsewhere in the vehicle? Crazy G has his somewhere off beat too
He can do that, because he doesn't have the stock gas tank, so it would be a similar setup, just longer piping. Also you need 2 of everything...
Reply 0
Feb 22, 2011 | 11:45 AM
Correct me if I'm wrong here guys... but it sounds to me the last thing he should do is buy any kit at all. With the application LiquidClen is attempting... he should look into buying the components he needs separately and have someone or a shop make the one off piping. Buying any kit would end up costing him more on the long run with excess useless parts.
Reply 0
Feb 22, 2011 | 11:47 AM
Quote: He can do that, because he doesn't have the stock gas tank, so it would be a similar setup, just longer piping. Also you need 2 of everything...
Hmm
Reply 0
Feb 22, 2011 | 01:00 PM
what are you even tryin to accomplish? adding parts for the sake of adding parts? You just cant add 2 turbos inline and say you have a sequential kit. YOu have to plumb wastegates together, along with bypasses, etc. Can it be done, sure. Does it make any sense or offer any benefits over current kits, no.
Reply 0
Feb 22, 2011 | 02:18 PM
Quote: what are you even tryin to accomplish? adding parts for the sake of adding parts? You just cant add 2 turbos inline and say you have a sequential kit. YOu have to plumb wastegates together, along with bypasses, etc. Can it be done, sure. Does it make any sense or offer any benefits over current kits, no.
Minimize (read: eliminate) Turbo Lag, Maximize torque (specifically low end)
Reply 0
Feb 22, 2011 | 02:37 PM
Thats what I dont get about all of this, to me sounds like OP doesnt know much about the FI world and read about sequential turbos and thought it was a good idea
so is the purpose of doing this just to eliminate turbo lag? because doing all this work its gonna make it way more expensive that just getting a TT.
go w/ a powerlab kit, those GT35s spool pretty fast and make killer power
Reply 0
Feb 22, 2011 | 02:56 PM
Quote: Thats what I dont get about all of this, to me sounds like OP doesnt know much about the FI world and read about sequential turbos and thought it was a good idea
Quote: Let me reiterate, my knowledge of FI is limited, so I may be very off base with all of my ideas.
Kind of.
Quote: so is the purpose of doing this just to eliminate turbo lag? because doing all this work its gonna make it way more expensive that just getting a TT.
Quote: Minimize (read: eliminate) Turbo Lag, Maximize torque (specifically low end)
I didn't think it would be more expensive than a TT, which was apparently my first fallacy. If (when) I go FI, I would like to have more usable low-end torque, as opposed to having the Turbo spool up at 5k RPM's
Reply 0
Feb 22, 2011 | 03:03 PM
my turbonetics hit full boost around 3700rpm, which wasnt that bad as you would think. powerlab was even sooner iirc
but I hear ya about having lots of low-end torque, my current car hits max torque at 1800rpm
Reply 0
Feb 22, 2011 | 03:08 PM
Quote: my turbonetics hit full boost around 3700rpm, which wasnt that bad as you would think. powerlab was even sooner iirc
Nice what kind of set up do you have currently?
Reply 0
Feb 22, 2011 | 03:09 PM
The question here is... will the minimal difference between the current Turbo setups and a sequential setup justify the overall Price Tag.
The other question you should ask yourself is what kind of power you plan on going too. If you don't plan on building the motor then I don't see any point in this whole thread. For a tune of around 420 to 450WHP on a stock block... there will be no point in building a sequential setup since the actual turbo is already small enough were Lag is already minimal to none.
I can only see a sequential setup even worth doing if you plan on going +600whp. Even then... there's better and cheaper ways of doing this from Spraying on earlier stages of your rpm to even Super Charger/Large Turbo Combo.
Reply 0
Feb 22, 2011 | 03:28 PM
Quote: Nice what kind of set up do you have currently?
BMW I6 TT
Reply 0
Feb 22, 2011 | 03:29 PM
N52 > n54
Reply 0
Feb 22, 2011 | 03:58 PM
  #30
too much code here beeeeemer guys hahahahahahahahaha
Reply 0
