Ichiba Wheel Spacers...5/10/15/20/25/30/38mm V1 + V2 available!
Old Feb 3, 2010 | 04:30 PM
mrwong@statik's Avatar
Ichiba Wheel Spacers...5/10/15/20/25/30/38mm Version 1 and Version 2 Available!!
New Version 2 30mm and 38mm Spacers Available!!!
Looking for Spacers? Everywhere not cheap enough? Well look no further.
Shoot me a PM and I'll be more then happy to hook you guys up!
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Bolt Pattern: 5/114.3
Center Bore: 66.2
Thread: 12x1.25
Longer Studs Included
Sold as one pair (2pcs) with 10pcs longer studs.
Ichiba NS-50205 Spacer V1 5mm
Ichiba NS-50210 Spacer V1 10mm
Ichiba NS-50215 Spacer V1 15mm
Ichiba NS-50220 Spacer V1 20mm
Description:
Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Spec:
Center Bore: 66.2
Thread: 12x1.25
Note:
Sold as one pair (2pcs) with 10pcs nuts
Ichiba WS-25511466A Spacer V2 15mm
Ichiba WS-25511466B Spacer V2 20mm
Ichiba WS-25511466C Spacer V2 25mm
Ichiba WS-25511466D Spacer V2 30mm
Ichiba WS-25511466E Spacer V2 38mm
~PM~ For Pricing too low to post!
Old Feb 4, 2010 | 12:49 AM
New 30mm and 38mm Spacers available = )
Old Feb 4, 2010 | 05:04 PM
JBF's Avatar
JBF
30mm and 25mm v2 shipped to 93505 please!
Old Feb 5, 2010 | 05:54 PM
WTF??'s Avatar
Bump for MrWong
Old Feb 5, 2010 | 11:35 PM
O HELLA OEM's Avatar
ichiba V2
25mm and 30mm shipped to 15122
thanks
Old Feb 6, 2010 | 01:04 AM
Invalid_User's Avatar
bump for the lowest price i ever seen for brand new spacers.
No group buy needed here
Old Feb 6, 2010 | 01:25 AM
Aw Thanks homie = )
Old Feb 6, 2010 | 02:46 AM
marcellsr's Avatar
10MM shipped to 93550
Old Feb 6, 2010 | 02:49 AM
laksjd84's Avatar
a pair of 15mm V2 shipped to 60007
Old Feb 6, 2010 | 02:58 AM
smr514's Avatar
v2 10mm and 20mm shipped to 90021
Old Feb 6, 2010 | 06:27 AM
pms replied..
Old Feb 8, 2010 | 04:16 PM
RST531's Avatar
2 quotes please.
1st - ichiba V2, 25mm (2 sets)
2nd - ichiba V2, 25mm and 30mm
picked up in person, if possible.
Old Feb 9, 2010 | 08:11 PM
pms replied..
Old Feb 9, 2010 | 10:19 PM
1st - ichiba V2, 25mm (2 Pairs=4 spacers)
2nd - ichiba V2, 25mm and 30mm (2 Pairs)
PM me prices for both shipped to 15122
thanks
Old Feb 11, 2010 | 02:50 AM
Thinkdiesel's Avatar
Those 38MM are BAAADAAASSS ,great vendor to work with!
pics soon, for the skeptics! engulfs my extended studs bwahahaha NOT FOR THE WEAK OF HEART
