FS: OEM O-Ring, OEM Idler Pulley Delete Spacers, OEM G37 Oil Filter Stud
Alright guys back in the day when I was doing deletes, wire tucks, and so forth........I have extra parts that I purchased in Bulk from Nissan to save the forum members time from having to wait on parts when doing these specific deletes and swaps.
First off I have OEM Spacers for the idler pulley/pulley bracket delete.
Basically whenever you delete the idler pulley from the front of the engine bay to clean up everything you have to keep the "GAP" that the idler pulley bracket provides. Normally you would have to get hack-saw or dremel and trim off the idler pulley bracket end. This spacer is what you put in place whenever deleting it. Take note that the idler pulley is a pointless pulley in our engine bays. It was only on the car for manual fans in 2003.
Price: $10.00 shipped a piece. Even though Nissan sells as a $3.00 spacer the shipping online is 12-15.00.
Spacer (13298-4P10A)
Pics:
Secondly I have done alot of work on cars and most members have problems with Camshaft positioning sensors going bad and crankshaft sensor.
After talking to techs at Nissan and the parts guys there is actually a replacement O-ring that can be installed that fixes the Sensor problems. Most really do not go bad its the O-rings that go out and cause the problems.
With that being said whenever I picked up 3 O-rings and installed them and cleared my codes I never had one come back. Im not saying this will fix yours specifically but for the price its worth the try over a $150.00 sensor.
These were not in stock either and were on back-order so I picked up quite a few for local members since these seem to be a common problem on our g35/350z.
http://www.infinitipartsusa.com/Infi...21314m505-.htm
Price: $6.00 Shipped a piece. Bundle with 3 to replace all will make a deal.
Part: 22131-4M505
Pics:
Pics:
Part: 22131-4M505
Pics:
bump for good seller
