FS: Engine bay wiring harness partout!!!
Old May 8, 2013 | 08:14 PM
DEMoLITIoN's Avatar
Off of a 2004 350Z. I bought this to use for a VQ swap and only took the plugs I needed
I am parting out individual plugs
$5-$50 depending on the plug. I suggest you make me an offer when you contact me.
I will ship flatrate USPS Small Box ($6) or Envelope (free)
I will keep an updated list of plugs that have been sold
E1 Fusible Link Holder
E2 Fusible Link Holder
E3 IPDM
E4 IPDM
E5 IPDM
E6 IPDM
E7 IPDM
E8 IPDM
E9 IPDM
E10 SOLD
E11 SOLD
E12 SOLD
E13 CANADA
E14 CANADA
E15 CANADA
E17 Ground
E18 Fuse Box
E19 Back Up Lame Relay
E21 Fusible Link Block
E22 Ground
E23 Hood Switch
E24 Front Combination Lamp RH
E27 Front Wheel Sensor RH
E28 rear washer motor
E29 Front washer motor
E30 washer level
E31 to something else
E32 horn
E33 horn
E34 ambient sensor
E35 horn
E36 horn
E37 crash zone sensor
E38 cooling fan motor 1
E39 cooling fan motor 2
E40 front combination lamp LH
E42 front wheel sensor LH
E43 ground
E44 brake fluid level switch
E51 ABS
E52 front wiper motor
interior stuff too.
Old May 9, 2013 | 10:14 PM
350z006's Avatar
Do you happen to have the plug for the maf sensor?
Old May 10, 2013 | 12:21 PM
DEMoLITIoN's Avatar
That is on the motor harness. This is the engine bay harness.
Old Jun 7, 2013 | 03:07 PM
DEMoLITIoN's Avatar
MAF sold
Old Jun 10, 2013 | 04:25 AM
Ampvqfanboi's Avatar
Would the harness that runs from the post cat o2 sensors to ecu be available?
Old Jun 14, 2013 | 04:17 PM
muhtish's Avatar
Question...Would you have a harness for Power Steering?
Old Jun 17, 2013 | 10:42 AM
DEMoLITIoN's Avatar
I will check and see what this runs to
Do you know which plug it is?
Old Jun 18, 2013 | 12:39 PM
muhtish's Avatar
Sorry bud, just re -read your post, and I don't think 06 G matches with wiring harness of 04 Z.
Old Jun 19, 2013 | 12:14 PM
DEMoLITIoN's Avatar
Plugs and colors are the same. Routing is different. If you need a pigtail, it will work just fine. let me know.
Edit: MAF sold!
whattf
Sep 1, 2015 07:42 PM
03sedang35
Aug 29, 2015 07:56 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
