South Serving AR, LA, MS, NM, OK, TX
Wheel Offset Calculator
Old Mar 9, 2007 | 05:33 PM
dan61177's Avatar
Ok this is mainly for gsRt5 who asked me about offsets and Rolling fenders and what not. I do not believe that you would need to roll your fenders to put 19s on they sell 20s specifically for the G35 Sedan. I don't know if there is any difference in the Sedan and Coupe offset. I run 20s on my coupe and I have no problem. Anyways here is a calculator for Offset. Hope this helps The stock Offset on the Sedan is 40mm
-->Wheel Offset Calculator<--
-->Tire Size Calculator<--
Old Mar 9, 2007 | 05:42 PM
dan61177's Avatar
After some research I would say go 20x8.5 front and 20x10 in the rear with 245-35 front and 275-30 rear and 34mm offset front and 40mm offset rear. You shouldn't have any clearance problems.
Old Mar 9, 2007 | 06:04 PM
gsRt5's Avatar
thanks again......Lemme see what the two wheels that I am looking at offer asfar as offset.....Its either going to be the Axis Pentas or the 5zigen Sc3000(?) that I will be getting.....I wouldnt mind going for the Work VsXX but my girl drives this car too and I can imagine how long it will be until see hits a curb...........
Old Mar 12, 2007 | 04:02 PM
Crashtest77's Avatar
Does anyone know if this would be the same size for the coupe.Those are the same size rims I'm looking to put on my coupe,but want to know if that would be the same offset or is that for the sedan?
Old Mar 12, 2007 | 06:42 PM
dan61177's Avatar
Not sure mine are 20mm offset with 350z H.Techs and I have no problems.
Old Mar 13, 2007 | 10:01 AM
Sweet.I will try those rims out,hopefully it will work,someone else had them,so should be fine.A different set that is,but they looked good.
Old Mar 14, 2007 | 12:01 AM
(>")> G35's Avatar
Whoa! For a sedan? Those offsets are looking for some serious rubbing. For the front I would get a 20x8.5" wide rim with a +35 offset. The rear I would run a 20x9.5 with +45 offset.
I have the 5zigen SC3000 on my sedan. The fronts are +38 and they aren't prefectly with the fender, a +35 would line up. The rear is a +45 and it's perfectly lined up.
Old Mar 14, 2007 | 06:52 AM
dan61177's Avatar
Um what?? I quoted +34mm offset and you said +35mm and I quoted +40mm offset and you say +45mm. Not much of a difference there. Do some research. I have found about 30 threads of people saying +34mm offset front and +40mm offset read for a perfect match. I personally have +20mm offset front and rear on my '04 coupe with no problem but since I dont have a sedan I did what's called RESEARCH. I didn't just open my mouth and see what kind of diarrhea flew out. And like I told him, no matter what rim you go with ...... call the rim manufacturer. They usually have a list of what offsets fit which car the best.
Old Mar 14, 2007 | 01:57 PM
(>")> G35's Avatar
Those offsets you posted work, but they will rub with out rolling your fenders. The rears will stick out with the 10" +40. Post this in the sedan forum and see what they tell.
EDIT
Also I do have a sedan and have wheels on my car, so I know from experience and research I've done what works and what doesnt.
Old Mar 19, 2007 | 05:51 PM
chobble19's Avatar
^+1 yup even a +45 offset of a 10" rear wheel would rub on a sedan and need fedner rolling. i even had to roll mine with the oem coupe wheel offset
obender66
18 Inch
Mar 13, 2016 12:20 PM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
