SouthEast Serving AL, FL, GA, KY, NC, SC, TN
Jax guys with a dremel?
Old Apr 21, 2004 | 12:58 PM
JaxG's Avatar
Any of you jax guys good with a dremel? Im getting this bluetooth car kit, and I want to install the buttons where the heated seat controls usually are (I dont have heated seats).
Here is what the buttons look like:
It has a wire going to the buttons, but I want to try to cut a precise hole, and mount it from underneath so it looks stock and no wires are anywhere.. ideas, input?
2003.5 Sedan / White & Willow / Premium / Navi / Sport / Aero
Old Apr 21, 2004 | 01:03 PM
JaxG's Avatar
Re: Jax guys with a dremel?
here is the pic:
Old Apr 21, 2004 | 01:08 PM
Meatshackle's Avatar
Deep Sea Moderator
I'm good with one only because I've messed up so many times. Use tape over the "finished" areas so when you catch an edge you don't dig a trench. Do as much from the back as possible. When it comes to getting a good right angle, use a file instead of the dremel at the end.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Apr 21, 2004 | 02:24 PM
speedeezx's Avatar
You can use mine, let me know
Old Apr 21, 2004 | 08:17 PM
DED's Avatar
DED
I have one if you come to Orlando.
Coming home from work today, I was like, why is it so hot in here??
I hit that stupid button. Be glad you have no heated seats. The truck release and VCD swith should be in that location.
2004 G35C 6MT Black. Sweet.
Old Apr 22, 2004 | 10:15 AM
JaxG's Avatar
Thanks for the tips Russ. I hope that part isnt too expensive incase I screw it up! Oh by the way. How do I get that part off? I know youve practically taken your whole car apart...
Thanks Doug, I definately will need to borrow it if you dont mind. Thats one tool I dont have yet. I will let you know when I get ready to do it.
Old Apr 22, 2004 | 10:40 AM
Deep Sea Moderator
Not sure on the sedan but on the coupe you pop off the ring around the shifter but prying on the back end of it. There are a couple of screws under there and also a couple between the seats and the armrest (slide seat forward).
On my latest dremel project I found out a good razor knife works really well for trimming. You can do just about the whole job with it. Then get some 600 grit sandpaper for the edges. I started my project with a dremel but did most of the work with the razor.
Russ
Black 6MT Coupe
Jax, FL
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Decimus141
Aug 13, 2015 08:42 AM
Detailed Image
Aug 10, 2015 02:29 PM
