where to getutec installed LA or SB
Old Jun 4, 2007 | 05:15 AM
Sasanpasta's Avatar
Im looking into getting a utec, and the last place i checked told me i had to get a wideband 02 and knock sensor installed along with a bunch of other crap, totalling 3K+. And to top it off the place that was going to do the work was in the IE, not as convenient as i would like.
Does anyone here know of a good place to get a UTEC installed and tuned either around Santa Barbara, LA, or inbetween? preferably someone who wont f**k me just because i drive a g35. any input would be great.
Thanks,
Sasan
Old Jun 4, 2007 | 01:01 PM
ISMSOLUTIONS's Avatar
You should be able to pickup everything you need for about $1400 - TOPS!
Install for the main unit is easy. You'll need an O2 bung installed before your CATS for the wideband - but you really don't NEED a wideband gauge. Your not FI, so your needs are limited and tuning easier to accomplish. So I would expect install to take about 2 hours - and hour or less for someone who has done it before. Also, if you get the remote MAP unit, that will need to be wired in and mounted somewhere.
Realistically, a stereo shop can do the install with the directions in hand. You'll need and exhaust shop for the wideband O2 bung though.
As far as tuning - should be 2 hours ore less - so about $200 or so. You should be able to do it all for $2000 or less. You can install the unit and items yourself, if your capable, and you can even tune it pretty good on your own if you have a laptop as well.
PM KenK2 for some help and maybe a starting MAP...he's really good with the UTEC.
Rick
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
