Hey WaLLy
Originally Posted by skaterbasist
That M3 is jaw-dropping!
Get an exhaust Wally. The last time I was at LACR (
), there was a gang of M3's all over the place. Most of them were too raspy for my taste, but there was one in particular that sounded insane; it was deep, but growled when he floored it. Very exotic sounding! But its your job to find out what exhaust it was.
the best 'muscle' V10 exhaust i've ever heard was on an M5 from a vid someone posted a couple weeks back.
i think it was something like masterscheif or something like that lol. maybe that brand will sound good on the M3. i'll look for the clip
This sounds almost as good as my bros Go-ped!
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/MeL7k06U2kw&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/MeL7k06U2kw&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
This one sounds good though......
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/I_0KXROB4f0&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/I_0KXROB4f0&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Its Meisterschaft... LOL
Here it is on an M5: <object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/vRYYe0kLCto&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/vRYYe0kLCto&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
I dont like it on the M3 though, it sounds too 'farty'.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/_1IUE_SyKYg&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/_1IUE_SyKYg&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
M3 Exhaust.......
With the exception of the second clip all the rest either sound raspy or way
too loud for a quality ride. Deep and mello is the way to go with the M3!
Damn! That's a sick looking M3. Sometimes I wish I would have gotten an M3 instead of another G. But I love my G too. Ahhhh . . . . I wish I could have both!!
besides, I'm still not done with the remodeling
my home>carI heard the sound clips and honestly, I don't like either of those. I've heard the Dinan in person before and I like it! But no exhaust or any mods to the M3 right now. Wish I had a few money trees growing on my yard lol
Originally Posted by WaLLy
no performance mods just yet. I've only done asthetic mods.. the last shipment I got a day before the accident was the last of it though. I need to reach the real goal which is FI.
my home>car
Although I never understood why the left two tips were plugged.
^^^I didn't even know they were plugged!
Looks sick!
When it comes to the E46 M3 muffler, however, the vehicle design apparently did not lend itself to the more traditional twin muffler approach, necessitating a “split” within the single muffler case in order to feed the four tips. This design requires that the exhaust flow changes direction, as indicated in the following diagram, increasing back pressure. As there is clearly no room available to install a second muffler on the M3, improved flow had to come from design changes within a single muffler case.
Literally months of testing demonstrated conclusively that requiring exhaust gasses to make 180 and 360 degree turns within the stock muffler’s internal chamber results in a large increase in back-pressure. Our pressure-tap measurements indicated 1.1 PSI at peak power (333 hp @ 7900 rpm). Analyzing other after-market manufacturer’s mufflers revealed high backpressure readings as well, due to the fact that they employ a similar design to the stock system, albeit with larger internal chambers and tubing. This particular design also results in an exhaust note that is, apparently, unappealing to many M3 owners. The additional components necessary
to direct the exhaust gasses to the four tips also increases the weight of the systems.
Despite mounting pressure from M3 owners to deliver the Dinan exhaust, we made a conscious decision to continue working toward a design that accomplished our stated objectives. While we certainly would have preferred to begin shipping the systems sooner, I simply won’t accept compromises when it comes to performance. We worked and worked at designs that would maintain the dual exhaust outlets, but each iteration resulted in a heavy, tinny sounding exhaust note with far too much back-pressure to produce any substantial power gains.
The Dinan Soulution
After analyzing many designs, we came to the conclusion that a more radical approach was required in order to produce a truly high performance exhaust. Further pressure tests and dyno runs confirmed our suspicions about the best approach for the E46 M3 muffler. Adopting a completely new design approach resulted in a significant improvement in flow, reducing backpressure by 82% at only .2 PSI. The exhaust note became throaty and aggressive, without being so loud that it would disturb or annoy any self-respecting enthusiast. Weight was reduced from 58 to 43 lbs., relieving the load by a full 26%.
As you can see from the diagram below, our M3 exhaust utilizes the two outlets on the right side of the muffler only. Recognizing that the four tips have become a significant visual design element for modern M-cars, as well as the fact that the rear valance has a cut out for the tips on the left side, the second set of tips were retained. While they are non-functional, the Mcar look is retained without compromising performance. The 3" tips have been ceramic coated for a striking high performance look, while eliminating any concern over uneven discoloration
that would occur with polished stainless. Surveys conducted among M3 owners verified that the audible source of the exhaust output could not be pinpointed as coming from one side or the other. The Dinan Free Flow Exhaust was ready for production.
The Dinan Soulution
The system produces measurable power gains, looks great and produces the exhaust note M3 owners have been waiting for. I believe that this latest exhaust design underscores the importance of real engineering, extensive testing and employing the highest quality materials. BMW-like fit and finish combined with the best warranty in the business makes for the definitive solution for your high performance M3 exhaust.
