June Factory Maintenance Specials @ EDO Performance!!!!!
Old Jun 12, 2008 | 06:08 PM
EdoPerformance's Avatar
OH SNAP! Summer is already here! New WRX's, New STi's, New parts to install! Okay...just another excuse to give you all discounts on our services. Who's gonna complain?
With hot temperatures comes hot hot hot prices!!!!!!
Oil Changes
- Mobil 1 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $68 NOW $60
- Motul 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $75 NOW $70
- Motul 300V 5W-30 Synthetic Oil with Zero/Sports Oil Filter WAS $99 NOW $90
Transmission and Differential Fluid Changes
- Transmission: Motul 75W-90 Synthetic Gear Oil WAS $110 NOW $100
- Differentials: Motul 75W-90 Synthetic Gear Oil WAS $70 NOW $65
- COMBO Trans and Diff: Motul 75W-90 Synthetic Gear Oil WAS $175 NOW $150
Radiator/Coolant Fluid Changes
- RedLine Water Wetter WAS $69 NOW $65
- Motul Inugel Optimal Organic WAS $69 NOW $65
- Motul Inugel Expert Hybrid WAS $79 NOW $75
Brake Services
- *Motul Brake Fluid is used on EVERY Brake Service!
- **Add an additional $7 for Motul RBF600 Fluid!
- Zero/Sports Stainless Steel Brake Lines (Front and Rear) $240 INSTALLED!
- Zero/Sports Front "Street" Brake Pads $175 INSTALLED
- Zero/Sports Front "Sport" Brake Pads $225 INSTALLED
- Zero/Sports Front "Circuit" Brake Pads $255 INSTALLED
- Zero/Sports Rear "Street" Brake Pads $165 INSTALLED
- Zero/Sports Rear "Sport" Brake Pads $215 INSTALLED
- Zero/Sports Rear "Circuit" Brake Pads $245 INSTALLED
- COMBO Front and Rear Pad Packages available! Please PM for pricing!
Clutch and Flywheel Installations
Bring your favorite clutch and flywheel and get it installed for $500*
* Motul Gear Oil will be used to refill your transmission fluid.
Factory Mileage Maintenance Services
30,000 Mileage Service
- Inspection of drive belts and camshaft belts
- Inspection of fuel system, lines, and connections
- Inspection of air filter (replaced with Zero/Sports N1 Filter if necessary)
- Inspection of brake pads, linings, and lines
- Inspection of ATF/Power Steering Fluid
- Inspection of front and rear axle boots and axle shaft joints
- Inspection of clutch, steering, and suspension systems
- Inspection of tires (and rotation if permitted)
- Engine oil replacement with Motul 5W-30 Synthetic Motor Oil
- Engine oil filter replacement with Zero/Sports Oil Filter
- Engine coolant replacement and system/hose inspection for cracks/leaks
- Transmission and Differential fluids replaced with Motul 75W-90 Synthetic Gear Oil
- Brake fluid replaced with Motul Brake Fluid**
- WAS *$480! NOW $470
60,000 Mileage Service
- 30,000 Mileage Service is performed
- Fuel Filter replaced
- Spark Plugs replaced
- WAS *$560! NOW $550
90,000 Mileage Service
*Additional fees may be added for automatic transmission vehicles and for replacement of air filter. Customer will be notified of charges in advanced.
**$7 additional fee if Motul RBF600 Brake Fluid is requested
Stay tuned as I will keep this thread constantly updated with up-to-the-minute sales and installation specials!
The next tuning session is here already! The 19th-22nd to be exact! Utec and EcuTek folks, bring your car and get tuned by The Legend! Tunes will start off at $400!
Thanks folks!
-Robert
EDO Performance
16182 Gothard Street, Unit P
Huntington Beach, CA 92647
714-602-5741 ext. 15
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
TurTLe*
Sep 29, 2015 01:43 PM
DRG35R
Sep 16, 2015 05:33 AM
