plenum spacer problem
Old Jun 23, 2008 | 05:50 PM
the420man's Avatar
for those of you who have a plenum spacer on your car.. when you first slap it on does the check engine light go on? because mines does and it kinda bothers. will dealer take this is and have it checked up and reset the problem with out taking it out? or will they wont even touch the car since you did mods to it? any suggestions would help. Thanks in advance!
Old Jun 23, 2008 | 06:04 PM
lekker_droom's Avatar
should not come on.
dealer may or may not help you out. I would count on not helping you out unless you wanna pay for it just like any other shop. obviously they may not cover it under warranty.
reset your computer for starters and see if it goes away.
Old Jun 23, 2008 | 06:21 PM
G37Rider92649's Avatar
did you install this while you were high???
Old Jun 23, 2008 | 06:23 PM
mIKE's Avatar
if we installed it for you, we will take care of it
Old Jun 23, 2008 | 07:27 PM
rickychampion's Avatar
Your car might have a vaccum leak or you might have not not reconnected a connector. make sure all the hoses are on and the plenum bolts are the correct tq specs.
Old Jun 23, 2008 | 07:30 PM
Hi-TechG35's Avatar
If you have to take it out and take it to the dealer. Don't tell them you've modded it otherwise you can kiss your warranty good bye.
Old Jun 23, 2008 | 07:35 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^WHS
The other common problem is trapping the rubber piece that goes around the oil fill cap in between.
Old Jun 23, 2008 | 07:46 PM
the420man's Avatar
i didnt have to take any of the hoses off.. it was just a quick bolt on. and like 5 minutes into the ride the light came on.
Old Jun 23, 2008 | 07:47 PM
the420man's Avatar
Originally Posted by InTgr8r
^WHS
i made sure that rubber piece was'nt stuck anywhere... i dont think thats the problem
the420man's Avatar
well if i take it out and bring it to the dealer. taht means i have to take out intake and everything else that i modded to the engine too right? SH*T!!!
Old Jun 23, 2008 | 07:49 PM
the420man's Avatar
hey mike quick question... you drive a blue G with a full kenstyle kit? and if you do it. thats no charge right?
Old Jun 23, 2008 | 07:50 PM
the420man's Avatar
no.. i did it in the dark.
Old Jun 23, 2008 | 08:08 PM
you sure you didnt disconnect anything, when I did my spacer I had to disconnect hoses and electrical connectors. If you didnt take anything off it is a good possibility that you may have ruptured a hose or broken a wire. you should pop the hood turn your car on and listen for vaccum leaks, listen for any hissing sounds.
Old Jun 23, 2008 | 08:33 PM
the420man's Avatar
i will try that.. the only tube i took out was the intake end that was connected to the plenum, thats it.everything else was on stuck on to the upper plenum. anything inside the plenum i should know about?
Old Jun 23, 2008 | 08:38 PM
Damnn shoulda done it high man......
JK JK....
Dude take it to a local shop that install performance parts and have them check it out, it will take care of your worries, i hate it when miscellaneous shiet happens in also.
