Service Manager Special: Tomei Camshaft and Gear Set Installation
Old Sep 19, 2008 | 01:13 PM
EdoPerformance's Avatar
Service Manager Special: Tomei Camshaft Installation
EDO Peformance Service Manager Specials
Tomei Camshaft Installation for VQ35DE
$1650 INSTALLED
DURATION : CAM LIFT(mm)
256° : 10.20 IN,EX
264° : 10.50 IN,EX
272° : 10.50 IN,EX / 11 EX, 11.3 IN
280° : 11 EX , 11.30 IN
* The above camshafts are sold as a pair for each side, either Inlet or Exhaust.
* Cams with cam lift greater than 11mm will require the valve springs to be upgraded.
* Cams with cam lift greater than 11mm will require valve recession on the standard pistons.
* Valve timing has already been adjusted, compatible with (eVTC) system.
* Not compatible with engine models with variable valve timing (eVTC) on the exhaust side.
(NOT compatible with the Z33 Anniversary edition from Sept 2005 onwards).
* While Stocks last
Email service manager Robert at robert@edoperformance.com if you have inquiries.
Old Sep 19, 2008 | 01:37 PM
Klubbheads's Avatar
Damn.... I wish i had the money right now. I would jump on this!!!!
Old Sep 19, 2008 | 02:03 PM
Service Manager Special: Tomei Gear set & LSD Installation
Service Manager Special: Tomei LSD T-Rax(R) and Gear Set Installation
$1580 INSTALLED
Tomei T-RAX aggressive cam angles design is optimized for drifting.
Features of Tomei T-Rax LSD Unit:
* Better Torque
* Better Response
* Heat Resistance
* Unmatched Durability
* Minimal Maintenance
Please feel free to email service manager Robert at robert@edoperformance.com
for inquiries.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Ashton35
Jul 22, 2015 09:19 PM
