FS: Hotchkis Adjustable Sway Bars 03-08
Old Sep 20, 2012 | 12:40 PM
sofa king's Avatar
v. 2 w/ collar. $290 shipped
http://www.conceptzperformance.com/C...&Car_Type=350Z
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs) 4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs) 3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Attached Thumbnails Hotchkis Adjustable Sway Bars 03-08-dsc_0086.jpg   Hotchkis Adjustable Sway Bars 03-08-dsc_0087.jpg   Hotchkis Adjustable Sway Bars 03-08-dsc_0088.jpg
Old Sep 20, 2012 | 12:53 PM
Ferrara's Avatar
Hey where are you located and why are you sellng them? I have been looking for a used set of these.
Old Sep 20, 2012 | 01:07 PM
sofa king's Avatar
Little Rock. i sold my G last November...deployed and just now getting around to cleaning out my garage .
azn_kiddd's Avatar
pm sent
Old Sep 22, 2012 | 07:26 PM
_GRide35_'s Avatar
payment sent, thanks
Old Sep 22, 2012 | 10:38 PM
sofa king's Avatar
sold
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
