FS[MidWest]: Want to go lower with your BC Coilovers? 160MM SPRINGS
Old Oct 3, 2012 | 09:39 PM
infinitifx45's Avatar
Talking **160MM 12K BC Racing Rear Springs**
If you want to go lower in your rear or UPGRADE your spring rate from an 8-10k to a 12k spring rate this is it!!! These springs are for the rear BC Racing Coilovers. You can see the differance between a 12K extreme drop kit spring which is a 200mm and this 160mm 12K spring.
they had about 20-30 miles before taking them off. "not 20-30k". These springs are ready to go packaged and ready to go soon as payment is sent. If you have any questions or interested in this spring you can PM me, emails me " carljaseleslie@yahoo.com" or call/text me @ 316-393-8569.
Thanks,
Old Oct 4, 2012 | 01:37 AM
s0calg's Avatar
lowest price shipped to 92507?
Old Oct 4, 2012 | 07:27 AM
$80, can ship today.
Old Oct 4, 2012 | 04:01 PM
s0calg's Avatar
how much would this drop my car do you know? I have the bc racing coilover set, but when i picked it up it didnt come with the rear springs or the mount for those springs.... So if I put these on, I'd have to keep it at the lowest height
Old Oct 4, 2012 | 04:10 PM
I can tell you how much it would drop it but I dont know your surrent setup or current spring options to go by. I can tell you the max it will go is about an inch under stock with the shock and spring adjustments raised up all the way. And it can go as low as tucking 19" rims and scrapping stock exhaust buy the rear flange "around axle". You will need the upper spring cup with the two adjusters along with the lower spring cup that sit inside the lower control arm for this set up or it will be way to low and/or your spring would not compress due to the shock not being valved to that height. contact BC Racing to get pricing on the stuff you need, or I can probably get it for you cheaper since I can order direct @ cost. If you can tell me want you dont have or send me pics of your setup now I should be able to tell. Thanks
Old Oct 4, 2012 | 04:15 PM
Also the pic of my avatar is an idea of how low they can go. I was on 19x11.5 -6 with 255/35 tires running -4.3 camber and the shock and spring cup was about 3/4 the way down. I stil had a couple inches I could play with, or even more if I removed the collets
Old Oct 4, 2012 | 06:37 PM
Here is an example of the standard extreme drop kit spring "right" vs the 160mm 12k spring "left"
Old Oct 4, 2012 | 06:40 PM
s0calg's Avatar
Damn thats a crazy difference. So the stock ones that come with BC coils are 200mm? or 230mm?
Old Oct 4, 2012 | 06:45 PM
200mm is the standard size they send in there extreme drop kit.
Old Oct 11, 2012 | 10:33 PM
Bump will take 60 shipped
Old Oct 22, 2012 | 04:42 PM
BUMP. nobody needs shorter rear 12k coils for there coilovers?
Old Oct 22, 2012 | 05:29 PM
s0calg's Avatar
Hmmm damn very temping. I just dont want my car to drop all the way to the floor. If i have it at the highest setting, i wont be too slammed right? I also needbto buy the rear spring mount or whatever you cal it
Old Oct 22, 2012 | 05:41 PM
s0calg's Avatar
I want these springs, but currently only have the front bc coilovers with the rear shocks. But im running a different set of spring without any of the bc spring cup and whatever else it needs to run these springs. Can you get a quote for me on those too. I believe you said you can get it cheaper?
Old Oct 22, 2012 | 07:48 PM
With these springs and the bc cup you will not be to slammed, in fact its a little over an inch from stock
Tell me what you need. Again and ill look into it.
Old Oct 22, 2012 | 11:27 PM
s0calg's Avatar
i need whatever parts the rear springs need. I have the rear struts already, so whatever i need for the other part
