FS: JIC Magic FLT-A2 Coilovers
Old May 2, 2013 | 02:06 PM
CH@Dbee's Avatar
I'm selling my JIC Magic FLT-A2 coilovers. They have about 8k miles on them and are fully functional with minor cosmetic blemishes as to be expected with a pre-used set of coilovers. The area where you tighten the collar is damaged on the rears but it has zero effect on the way the suspension rides, performs or the functionality of ride height adjustment. This is a high end suspension system that costs $2100 new and are very rare these days.
SOLD SOLD SOLD SOLD
FLT-A2 Series suspension kits are JIC Magic's flagship coilover setup! The FLT-A2 features lightweight, 15-way adjustable inverted monotube 40/45mm piston dampers that ensure high strength and fade free performance. The ride height is adjustable, separate from the spring perch giving maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings. Also features linear springs that give laser precision steering response in all kinds of harsh road conditions.
Coilover kits from JIC include upper pillow ball mounts for improved chassis stiffness and better handling while the MacPherson strut design helps benefit front camber adjustability providing built-in caster/camber adjustment. The multi-link suspension design features CNC machined aluminum lower brackets or high tensile steel brackets depending on the application.
15-Way Adjustable Dampening. Inverted Monotube 40-45mm Piston Dampers. Anodized Aircraft Aluminum Pillow Ball Upper Mount. Adjustable Height from ½ to 3-inch Drop. Duralumin 6061 Lower Seat. Cool-Bend Chrome Silicon Metal Linear Rate Springs. Rubber Bump Stops Prevents Bottoming Out. Aircraft Aluminum/Hard Steel Brackets.
$1050 + shipping
Old May 6, 2013 | 02:09 PM
CH@Dbee's Avatar
Ok I need to sell these, new crazy cheap price....this is bottom dollar
$900 + shipping/PP fees
Old May 6, 2013 | 02:15 PM
JaE35's Avatar
Moderator
G35 Sedan
Damn!
Old May 6, 2013 | 05:31 PM
CH@Dbee's Avatar
Originally Posted by JaE35
Damn!
Crazy good deal right?!
Old May 7, 2013 | 10:14 PM
digit2k5's Avatar
Fml
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
