Pop Charger / Clear corner Installation.
Old Dec 14, 2009 | 06:14 PM
Unkoman1's Avatar
I just bought a JWT popcharger/ztube combo along with some clear corners and was curious as to how much a mech would charge me to install these items. Look forward to hearing from you guys.
Old Dec 14, 2009 | 06:35 PM
DG_coupe's Avatar
please don't pay anyone to do your clear corners they just pop off when u pull from the inside will take 1 minute to change both. Also for the JWT pop charger if you wanted to do it yourself heres a great DIY http://www.myg35mods.com/tutorials/p...ube/index.html
Old Dec 14, 2009 | 06:39 PM
Unkoman1's Avatar
Thanks for the fast response.
I'm a new 'G' owner and new to this site and surprisingly I DID and DO read the Stickies for Noobies, which are very well done by the way. However I never considered the DIY approach. Maybe I should check it out and save the money for more mods.....thanks for the suggestion.
Old Dec 14, 2009 | 06:54 PM
Black Betty's Avatar
I'f you're hell bent to give your money to someone for this install, PM me.
Old Dec 14, 2009 | 07:59 PM
GeezNuts's Avatar
ha ha - I'll help you Jeremy!
Old Dec 14, 2009 | 08:28 PM
nghiars's Avatar
if you can change a light bulb(literally one in your home) you can install the corners. just grab the part thats closest to your wheel well and pull away from car.. it pops right off!!!! one more twist you can firgure out and you've taken it off. If you cant figure out how to put it back, you need a mech( doubt you will)
If you can loosen a few bolts, the pop charger can bi installed by you!
I'm usually lazy but these are so easy... 30 minutes to do both once you know what you're doing... which wont be long =D
Kelvin Style006
May 23, 2016 03:47 AM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
cmesidewayz
Sep 29, 2015 09:28 PM
spanky99l
Sep 7, 2015 12:46 AM
