Kinetix and Stillen Camber/Traction Arm Deals!!!
Old Nov 6, 2007 | 05:56 PM
Mike@CZP's Avatar
If you are ordering online, please put "g35driver.com member" in the comments section to have the price adjusted on your order. Click the "add-to-cart button below to order! Thank you!!
Kinetix 350Z/G35 Front Adjustable Control Arms : $250.99 Shipped!!
Complete upper control arm replacement allowing positive and negative camber adjustment of the front wheels. These arms will allow you to either add positive camber to your wheels (EXTEND tire life) or to add negative camber (increase handling). The front suspension from the factory allows zero camber adjustability which can become a problem especially when lowering your car. Race enthusiasts also wish to add more negative camber to increase their handling without having to "slam" their car to achieve the desired camber. These arms will allow 1.5 degrees of positive camber, and 1.5 degrees of negative camber from the factory settings. So if your car is lowered 1.5" and the front camber is sitting at 2 degrees negative camber, these arms will allow you to bring them back out to .5 degrees negative camber.
These arms are constructed entirely out of stainless steel for its superior stiffness, strength, and corrosion resistance. They are completey TIG welded and offer a huge upgrade in strength over the factory arms. They use ENERGY SUSPENSION polyurethane bushings for increased responsiveness over the factory rubber bushings. They also use a high quality 3-piece Heim ball joint protected by a polyurethane red dust bootie. These Heim joints offer the best in suspension responsiveness and smooth operation. These Heim joints are also high serviceable and do not require any special tools to remove.
Kinetix Racing 350Z/G35 Front Camber & Rear Camber/Traction PACKAGE : $524.98 Shipped!!
Front Upper A-Arms with camber adjustability for the 350Z and Infiniti G35 (2dr and 4dr)
Rear camber/traction PACKAGE for the 350Z and G35 (2dr and 4dr)
These adjustable camber arms will allow a full range of camber adjustment for your rear wheels. Also featuring upgraded ENERGY SUSPENSION polyurethane bushings, these arms are considerably stronger and stiffer than the factory arms.
These traction adjustable arms allow fine tuning of the rear suspension and allow slight adjustment of rear wheel toe. When lowering your car 1.5"-2" and adjusting rear camber back to spec, your toe will need to be pulled back into spec as well, which can be achieved with these arms. They also feature high quality ENERGY SUSPENSION polyurethane bushings for increased handling. The increased stiffness of the arm and upgraded bushing help to eliminate "wheel hop".
Fabricated out of stainless steel, with a stainless center turnbuckle for increased stiffness and strength. Center turnbuckle has fine threads for precise adjustability. Arms are produced in house and are precision TIG welded.
With both the camber and traction arms, you will full adjustability over your camber and toe when lowered up to 2" (past 2" and an additional modification to a factory arm is needed to bring everything back to spec, please email for details)
Kinetix Racing 350Z/G35 Rear Camber/Traction PACKAGE : $250.99 Shipped!!
Stillen 350Z/G35 Rear Adjustable Camber Arms : $333.00 Shipped!!
If you have lowered your car, your rear camber is off and the best solution for the correct suspension setup is STILLEN’s New Rear Camber Adjusters complete with Rod-Ends. Designed for race-precision adjustments and long service life, these rear camber adjusters are equipped with hemispherical rod-ends that allow incredibly controlled rear suspension travel & predictable response. They also improve handling and allow for even tire wear!
Old Nov 10, 2007 | 05:38 PM
Mike@CZP's Avatar
bump!!
Old Apr 7, 2008 | 01:42 AM
Mike@CZP's Avatar
bump
Old Sep 4, 2008 | 05:17 PM
Mike@CZP's Avatar
pm me for fast response
Old Sep 18, 2008 | 04:30 PM
Mike@CZP's Avatar
bump
Old Sep 23, 2008 | 02:25 PM
Mike@CZP's Avatar
bump
Old Sep 30, 2008 | 04:43 PM
Mike@CZP's Avatar
bump
Old Oct 7, 2008 | 05:30 PM
Mike@CZP's Avatar
bump
Old Oct 15, 2008 | 01:40 PM
Mike@CZP's Avatar
bump
Old Oct 21, 2008 | 04:40 PM
Mike@CZP's Avatar
bump
Old Oct 28, 2008 | 01:54 PM
Mike@CZP's Avatar
bump
Old Nov 4, 2008 | 11:26 AM
Mike@CZP's Avatar
bump
Old Nov 11, 2008 | 11:23 AM
Mike@CZP's Avatar
bump
Old Nov 18, 2008 | 03:32 PM
Mike@CZP's Avatar
bump
Old Nov 24, 2008 | 01:05 PM
Mike@CZP's Avatar
bump
