___ SPC Camber Kit Front and Rear HOLIDAY BLOWOUT | Save your tires and $$$ ___
Originally Posted by MPK1232
how much for revised front & rear kit (04 coupe) shipped to 91754, thx
Eddie
Is the Front Camber Arms: Nissan 350z/G35 03-07 (SKU 72120) adjustable? By looking at it, it doesn't seem to be able to adjust. Sorry I don't know much about this kit. Is this Camber Arm will fix my alignment problem. I currently have -1.5 Right front tire (OEM -1.2 to 0.3) and left front tire -1.6 (OEM -1.2 to 0.3)?
Edward
Originally Posted by THMotorsports
The front kit 72125 which is a new replacement for the 72120 (just updated) has full adjustment of 5 degrees of camber. It will fix your -1.6 and you can go back to the .07-.01 stock specs around. Order at the link on the first page so we may send them out today.
Edward
Edward
Anything that I need to be aware for the installation? Do I use everything that the SPC kit has included to replace the OEM parts or some OEM parts will need also? Will this kit turn my ABS break sensor light on or something because I read some of other's post on here, but I still doesn't understand what they were talking about. Thanks for the help.
All errors and issues have been resolved, so feel free to order
Edward
Now, you will use everything from the SPC kit including all bolts. It is a direct replacement with the new 72125 update on the 72120's. The lights will come on at first, but after alignment, it will be down to no lights at all.
Edward
Edward
Thanks, Ed. Last question. I used Tein 350Z H spring, I also read about revised camber arm or none revise one, What dose revised mean? Don't know which one to get, I have 04 G35 coupe. I promise this is the last question for today.
Thanks,
Edward
The Revised version reffers to the 72125 which is the only thing we sell now. SPC has superceded part number 72120, the old non-revised for the 72125 revised. Now you must order! haha
Thanks,
Edward
Thanks,
Edward
I will keep you in mind next.
Make sure you get the front cambers installed with the front tires, or else you will be buying tires again if you delay.
Here is the Bump for your help.
As for others, buy this kit quick before you end up like me paying over $800 for tires.
Originally Posted by idrive_MD
just curious what type of regular service do these require, i.e. bushing greasing, yearly alignments etc?
Edward
