HKS Hypermax III are comming!! Get yours now!
Old Feb 15, 2008 | 07:21 PM
Julian's Avatar
The Hipermax III, Hipermax III Sport and Hipermax CLX will be launched in North America on February 19th, 2008. The suspension will be available through Authorized HKS Dealers and HKS Certified Pro Dealers. The HKS Hipermax III suspension line is backed by a 1 year limited warranty.
Drawing upon more than 35 years of experience building high-performance equipment for the world's most discriminating drivers, HKS is the premier manufacturer of automotive performance systems. The Hipermax III line is available in three series, all specifically tuned for North American driving conditions: The Hipermax III series strikes a balance of track performance and a smooth ride. Hipermax III Sport is tuned for serious track performance. And the Hipermax III CLX series is designed for luxury cars to seamlessly blend fantastic handling and feedback with a smooth ride, even on less-than-smooth pavement.
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
Retail $1999
Order now $1699
shipped in theUS!!
Estimated ship date is on or around 2/19/08
Old Feb 19, 2008 | 06:49 PM
Julian's Avatar
bump
Old Feb 22, 2008 | 09:10 AM
JZ39's Avatar
What are the spring rates on these and the sport version?
Old Feb 26, 2008 | 01:43 AM
Alan's Avatar
Originally Posted by sharif@forged
Spring rates on the Hypermax III street is 9F/9R, and Hypermax III Sport 11F/12R.
from another thread
Old Feb 28, 2008 | 04:52 PM
Julian's Avatar
Originally Posted by Alan
from another thread
Thank you..
Old Feb 29, 2008 | 02:54 AM
AlterZgo's Avatar
When will the Hipermax III CLX be available for the 07+ G35 sedan? There are a bunch of us 2nd gen sedan owners waiting for a quality coilover.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
tiguy99
Jul 26, 2015 01:39 PM
TinoNT
Jul 24, 2015 12:16 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
