Suspension Deals Ohlins- KW- Tanabe-SBC Camber Kits $169-All Prices Beat
Old Mar 6, 2008 | 09:23 PM
gruppe-s's Avatar
Former Sponsor
Get ready for some of the best G35 suspension deals of the year. Ohlins coilovers now available for the hardcore race guys. Also HKS Hipermax II has landed and are ready to tear up the track. Looking for a simple drop in ride height the Tanabe GF and NF are your best bet. Also dont forget to order an SBC Camber system now at the lower price online. If you something here cheaper somewhere else we will beat it.
Ohlins DFV Coliovers
Height Adjustablility: Fully adjustable, independent base height adjustment
Settings: 20x
Piston size: 46mm
Precision: increased from 1kg precision to 100g
Quality: 7000 Super FORGED cylinder(NOT CAST)
light weight
High rigidity
mirror-like finish has been increased to a higher level
Teflon coated bolts and screws
6000 Super FORGING on the outer tube
PM for Price
KW Variant 3 Coilovers
Used by some of the top drift team in the world. During manufacturing of KW Coilover suspensions, the highest quality materials are used to produce individual suspension solutions that enable customers to adjust vehicle height according to their wishes and needs. Within the TÜV-tested adjustment parameters, this can be easily achieved using the purple-colored aluminum spring collars by adjusting the position of the yellow coated springs upwards or downwards via a specially designed exterior thread. In doing so, the vehicle height can be precisely adjusted, and customers receive exactly the result they want and/or need. The stainless steel strut housings are fitted the specific vehicle, and are available in three different damping technologies. With this variety, KW Coilover suspensions in Variants 1, 2 and 3 can meet the exact requirements of every customer. The complete systems including high-quality yellow springs, purple aluminum components and Elastomer bump stops with integrated dust protection system, provide a unique comprehensive solution for a personalized vehicle suspension system that meets all performance and quality demands.
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
PM for Price
HKS Hipermax III/ Hipermax III Sport
Now Available!!!
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
• 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Lightweight Aluminum lock nut & ride height adjuster
Hipermax III
Pm For Price
Hipermax III Sport
Pm For Price
Tanabe GF210
1.0 Front
1.2 Rear
$199 Shipped
Tanabe NF210
1.2 Front
1.2 Rear
$199 Shipped
Eibach Pro Kit
1.8 Front
1.2 Rear
$275 Shipped
SPC Adjustable Front Upper Control Arms
Front Adjustment range: Camber -1.5¡Æ to +3.5¡Æ
Caster ¡¾1.0¡Æ
The SPC Adjustable control arms you can finally tune camber and caster .
SPC Performance's new arm/shim kit has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting, allowing for precise changes when fine tuning suspension alignment angles necessary when racing or drifting.
The hub and caliper shims extend out the center of the wheel making it possible for the forged and fabricated arm to make up to 5 degrees total camber change and ¡¾1.0¡Æ degrees of caster change.
Using a sliding and rotating ball joint, you can fine tune both camber and caster to save tires and improve handling and tire to surface contact. The kit includes everything you need, including the ABS line re-routers, shims, and arms for both sides of the vehicle.
$365 Shipped
SPC Adjustable Rear Camber/Toe Arms
The SPC Rear Control Arms arethe perfect kit for the lowered Z, whether you are looking at high performance, racing, lowered, or extreme applications.
This kit provides plenty of adjustment for camber and toe. With the adjustable EZ Arm?camber can be changed up to ?.0? And the kit comes with a larger offset toe cam to bring the toe angle back into range.
$169 Shipped
Old Mar 6, 2008 | 10:58 PM
HEGONE's Avatar
Can you Pm me the BEST price with shipping for the front and rear camber arm's also the HKS hypermax III's.... THANKS!
Old Mar 11, 2008 | 04:54 PM
gruppe-s's Avatar
Former Sponsor
Pm sent
Old Mar 12, 2008 | 04:21 PM
gruppe-s's Avatar
Former Sponsor
Old Mar 14, 2008 | 06:49 PM
gruppe-s's Avatar
Former Sponsor
Old Mar 17, 2008 | 05:47 PM
gruppe-s's Avatar
Former Sponsor
Old Mar 17, 2008 | 06:03 PM
lekker_droom's Avatar
Kw!
Old Mar 18, 2008 | 06:52 PM
gruppe-s's Avatar
Former Sponsor
Originally Posted by lekker_droom
Kw!
KW?
Please specify what your question is?
Thanks
Old Mar 20, 2008 | 04:59 PM
rlin302's Avatar
Where do I place the order for SPC Adjustable Front Upper Control Arms? Also do you guys do installation?
Old Mar 20, 2008 | 05:03 PM
gruppe-s's Avatar
Former Sponsor
Old Mar 22, 2008 | 11:57 PM
Nilesh1001's Avatar
HKS Hipermax III shipped to 11367
Old Mar 24, 2008 | 06:27 PM
gruppe-s's Avatar
Former Sponsor
Pm Sent
Old Mar 25, 2008 | 06:51 PM
gruppe-s's Avatar
Former Sponsor
Old Mar 25, 2008 | 06:59 PM
gruppe-s's Avatar
Former Sponsor
gruppe-s's Avatar
Former Sponsor
