SPC Camber Kits$525-Cusco A-Arms$395-Tanabe Springs$195-Ohlins DFV-HKS Hipermax-KW V3
Old May 12, 2008 | 06:30 PM
gruppe-s's Avatar
Former Sponsor
All Suspension on sale guys. Dont miss out on these awesome deals. Check out Ohlins DFV and HKS Hipermax 3 now available. Also for a limited time all SPC alignment products on sale. Remember we will beat all others prices.
Tanabe DF210 Springs
G35 Coupe Lowers Vehicle F:1.7"/ R:1.3"
G35 Sedan Lowers Vehicle F:1.7"/ R:1.5"
G35 Sedan (07-08) Lowers Vehicle F:1.4"/ R:1.4"
G35 Coupe $195 Shipped
G35 Sedan $195 Shipped
G35 Sedan (07-08) $245 Shipped
Tanabe NF210 Springs
G35 Coupe Lowers Vehicle F:1.0"/ R:1.6"
G35 Sedan Lowers Vehicle F:1.6"/ R:0.9"
G37 Coupe Lowers Vehicle F:1.0"/ R:0.7"
Tein S.Tech Springs
G35 Coupe Lowers Vehicle F:1.2"/ R:0.9"
G35 Sedan Lowers Vehicle F:2.0"/ R:1.3"
G35 Coupe $299 Shipped
G35 Sedan $299 Shipped
SPC G35Z Front and Rear Camber Kit
The SPC Adjustable control arms you can finally tune camber and caster .
SPC Performance's new arm/shim kit has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting, allowing for precise changes when fine tuning suspension alignment angles necessary when racing or drifting.
The hub and caliper shims extend out the center of the wheel making it possible for the forged and fabricated arm to make up to 5 degrees total camber change and ¡¾1.0¡Æ degrees of caster change.
$525 Shipped
Cusco Adjustable A-Arms
Direct replacements for the front A arms and allow you to adjust camber on the front of your 350Z or G35. These employ a special compound rubber busing to ensure smooth operation and minimize noise. The actual amount of camber you can dial in or out will of course vary from car to car based upon suspension setup, rideheight, as well as your tire and wheel combo. However, these should provide more than enough adjustment to bring most any car back into the specs one could want (please note if your car is extremely lowered in front, depending on your particular setup you might not be able to adjust back to factory specs, though you will be able to scale back the total amount of negative camber. We installed these on our own 350Z, which is lowered with Cusco coilovers, and were able to bring the car back to -1.25 degrees in the front.
$395 Shipped
Ohlins DFV Coliovers
Height Adjustablility: Fully adjustable, independent base height adjustment
Settings: 20x
Piston size: 46mm
Precision: increased from 1kg precision to 100g
Quality: 7000 Super FORGED cylinder(NOT CAST)
light weight
High rigidity
mirror-like finish has been increased to a higher level
Teflon coated bolts and screws
6000 Super FORGING on the outer tube
PM for Price
KW Variant 3 Coilovers
Used by some of the top drift team in the world. During manufacturing of KW Coilover suspensions, the highest quality materials are used to produce individual suspension solutions that enable customers to adjust vehicle height according to their wishes and needs. Within the TÜV-tested adjustment parameters, this can be easily achieved using the purple-colored aluminum spring collars by adjusting the position of the yellow coated springs upwards or downwards via a specially designed exterior thread. In doing so, the vehicle height can be precisely adjusted, and customers receive exactly the result they want and/or need. The stainless steel strut housings are fitted the specific vehicle, and are available in three different damping technologies. With this variety, KW Coilover suspensions in Variants 1, 2 and 3 can meet the exact requirements of every customer. The complete systems including high-quality yellow springs, purple aluminum components and Elastomer bump stops with integrated dust protection system, provide a unique comprehensive solution for a personalized vehicle suspension system that meets all performance and quality demands.
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
PM for Price
HKS Hipermax III/ Hipermax III Sport
Now Available!!!
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
Hipermax III
Pm For Price
Hipermax III Sport
Pm For Price
Old May 13, 2008 | 06:05 PM
gruppe-s's Avatar
Former Sponsor
Old May 14, 2008 | 05:01 PM
gruppe-s's Avatar
Former Sponsor
Old May 15, 2008 | 05:12 PM
gruppe-s's Avatar
Former Sponsor
Old May 16, 2008 | 04:24 PM
gruppe-s's Avatar
Former Sponsor
Old May 16, 2008 | 05:40 PM
The Punisher's Avatar
do you have a front camber kit for the 07-08 sedan available?
Old May 18, 2008 | 12:04 AM
MPK1232's Avatar
is the spc kit the new revised version?
Old May 19, 2008 | 05:26 PM
gruppe-s's Avatar
Former Sponsor
Sorry nothing available for the Sedan as of yet
Old May 19, 2008 | 05:29 PM
gruppe-s's Avatar
Former Sponsor
I am not aware of a redisign. Here is the link to the rear arm.
http://www.spcperformance.com/PROD_D...d2=72050&cmd3=
Old May 20, 2008 | 06:23 PM
gruppe-s's Avatar
Former Sponsor
Old May 21, 2008 | 03:54 PM
gruppe-s's Avatar
Former Sponsor
Old May 21, 2008 | 06:28 PM
bobshuai's Avatar
Do you just sell the SPC front Camber Arm set?
Old May 21, 2008 | 10:34 PM
gruppe-s's Avatar
Former Sponsor
Arms are $379 plus tax for CA customers
Old May 22, 2008 | 09:21 AM
Beebo's Avatar
How much for SPC G35 Rear Camber Kit shipped to 79902?
Old May 22, 2008 | 12:37 PM
bobshuai's Avatar
PM sent
