Megan Racing Street/Track Coilovers
Old Jan 21, 2010 | 11:00 AM
ARCH Industries's Avatar
Premier Sponsor
ARCH Industries is happy to offer Megan Racing Street and Track Coilovers.
Email for the best pricing! sales@archind.com
Megan Racing
Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Old Jan 22, 2010 | 01:53 PM
Premier Sponsor
bump it up!
Old Jan 23, 2010 | 09:51 AM
STCLAIRWEST's Avatar
How much shipped to toronto?
Old Jan 23, 2010 | 11:31 AM
npc64's Avatar
shipped to 95120?
Old Jan 24, 2010 | 12:00 PM
Premier Sponsor
all PMs sent!
Old Feb 23, 2010 | 05:02 PM
Premier Sponsor
having a special on all Megan Coilovers!
Old Feb 25, 2010 | 01:16 PM
Premier Sponsor
bump it up for everyone =)
Old Apr 5, 2010 | 10:34 AM
Premier Sponsor
PM for the lowest pricing.
Old Apr 5, 2010 | 11:36 AM
g35man04's Avatar
CLUB MODERATOR
pm price shipped to 75069?
Old Jul 3, 2010 | 12:50 PM
Premier Sponsor
orders were all shipped yesterday =)
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
