New! Energy Suspension compression rod & diff bushings!
Apr 7, 2011 | 04:59 PM
so new bushings have grease fittings also i know there not available yet but PM for price possible
Reply 0
Apr 8, 2011 | 12:36 PM
There are no "grease fittings" on these bushings, you grease them before installation, and yes they are available. I've been selling them for two weeks now.
Reply 0
Apr 8, 2011 | 03:00 PM
So what's the difference in OEM the whole problem with our cars bushings isn't that they fail there just noisey because you can't keep greasing them like you can other cars if yours can't be greased either then is there a difference?
Reply 0
Apr 8, 2011 | 07:05 PM
Which bushing are you referring to exactly? The compression rod and front inner control arm bushings eventually tear because they are rubber. The front outer control arm bushing will swell at the bottom from the constant forces it receives from the front struts which support the weight of the vehicle. These are all reasons to upgrade to polyurethane, not to mention they will outlast the oem rubber ones because they don't deteriorate like rubber. If you are suffering from noise, your bushings may have actually failed. If they haven't, consider yourself lucky and don't worry.
Reply 0
Apr 8, 2011 | 07:09 PM
Oh ok sweet there poly
Reply 0
Apr 8, 2011 | 07:24 PM
so these cure the creaking noise on the front over uneven pavement?
Reply 0
Apr 11, 2011 | 07:16 PM
Quote: so these cure the creaking noise on the front over uneven pavement?
If you are experiencing a noise you should have the vehicle inspected by a shop. That noise could be caused by several different things including the sway bar bushings or even your front struts. I wish I had a simple answer for ya, but I don't.
Reply 0
Apr 12, 2011 | 03:55 PM
Bump.
Reply 0
Apr 13, 2011 | 08:07 PM
how much for the kits shipped to 75212
Reply 0
Apr 14, 2011 | 04:15 PM
price for both shipped to 20878
thanks
nick
Reply 0
Apr 14, 2011 | 06:04 PM
Front arm kit has sold out, more on order. Diff bushings are still in stock.
Reply 0
Apr 18, 2011 | 01:15 PM
bump
Reply 0
Apr 18, 2011 | 11:27 PM
any word on the compression rod bushings priced seperately?
Reply 0
Apr 19, 2011 | 12:26 AM
^ +1
Reply 0
Apr 19, 2011 | 01:10 PM
  #30
No, I am still not able to get them separately. No worries though, Whiteline's local rep dropped by yesterday and brought me their new Diff kit and will be sending me their compression rod bushings shortly, which will be sold separately. As soon as they are available for sale, I'll start a new thread for them.
Reply 0
