Momentum Performance Upper Arms Stance Toe Camber Arms
Old May 11, 2011 | 06:37 PM
THMotorsports's Avatar
Smile Momentum Performance Upper Arms Stance Toe Camber Arms
SUPER INTRO PRICING COMBO DEALS!!!
For those who need more performance form their G35 suspension we have some pretty cool parts to showcase!
Momentum Performance Upper Control Arms For 350Z - in stock!
The Momentum Performance Nissan 350Z/G35 Upper Control Arms offer a wide range of performance benefits for both track and daily driving.
Momentum Performance 350Z/G35 Control Arms make use of one-piece billet 7075 aluminum construction, which reduces the weight of these suspension components compared to the stock units while at the same time adding rigidity, strength and response – three important factors for drivers looking to “Push Forward” with their vehicle’s performance. Aurora spherical rod ends also improve the durability of the control arms by removing rubber bushings from the equation.
An additional advantage offered by the Momentum Performance 350Z Control Arms is the four-degree range of camber adjustability that helps track drivers dial in more precise suspension and alignment setups while also allowing street drivers to adjust for lowered ride heights in order to maintain maximum grip and reduce tire wear.
Fitment for 2003-2009 350Z/G35
FEATURES
CNC machined, aircraft grade 7075 aluminum
Black anodized design for aesthetics and durability
Aurora rod ends with Grade 8 locking hardware
CNC machined mounting spacers and ball joint adapters
ADVANTAGES
Allows use of factory frame mounts and hardware
+/- 4 Degrees Camber Adjustment
Branded with Momentum Performance logo
From the company that brought to you some of the most toughest and high performance suspension systems, STANCE is bringing more control to the table with their new Aurora spherical rod end equipped suspension links.
STANCE - Nissan Z33 Rear Toe Rods
Adjustable toe rods in the rear allow the driver to tune the chassis to any individual's driving characteristics, style, and experience. The amount of Toe-in and -out will allow the rear tires to respond according to each driver's needs. STANCE Rear Toe Rods are a must for any serious driver looking to maximize control over their toe specs.
Note: You must have "true" coilover type to use this link. This link replaces the OEM lower arm that has the spring housing.
Nissan Z33 Rear Camber Arms (RCA)
Rear Camber Arms are an ideal suspension modification after lowering any Z33. The RCA will allow for proper rear camber adjustment and aid in maximizing handling and braking abilities while saving tires from uneven tread wear. In addition the arms will also keep the camber true during hard/competition drifting or racing.
The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. The Stance links use Aurora's strongest billet 3 piece rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability. Our rod ends offer a high misalignment angle for extreme performance.
PM US OR CALL US FOR BEST PRICES AVAILABLE AND FOR ANY DESIRED COMBO DEALS!!!
Looking forward in hearing from you.
Thank you,
Adam
THMotorsports
800-959-0145
www.thmotorsports.com
adamk@thmotorsports.com
AIM = adamkthm
Old May 12, 2011 | 03:54 PM
PMs sent!!!
LMK guys!
Old May 12, 2011 | 11:53 PM
gfanatic's Avatar
prices for front and rear arms shipped to 95747? thank you
Old May 13, 2011 | 03:13 PM
you have PM!!
Old May 13, 2011 | 05:04 PM
Anh's Avatar
Anh
Front arms and rear toe/camber arms for 2004 G35 Coupe shipped to 70072 please.
Old May 14, 2011 | 03:44 AM
whodiduexpect87's Avatar
How much for the upper control arms shipped to 11427?
Old May 16, 2011 | 03:13 PM
PMs sent with sweet intro prices!!!
Old May 20, 2011 | 03:48 PM
Happy Friday Everyone!!!
-Adam@THM
Old May 23, 2011 | 08:12 PM
Old May 24, 2011 | 07:20 PM
Thank you for all the orders and all the support!!!
Adam@THM
Old May 24, 2011 | 07:21 PM
Adam@THM
Old May 24, 2011 | 07:23 PM
B L U E S L A T E's Avatar
Honda Accord
All these parts for Z33 and V35 cars, yet there ins't any development I see in V36/Z34 cars. What's the deal? :/
Old May 25, 2011 | 01:27 PM
Its always like that...but the suspension pieces in both cars are interchangeable...slight differences.
Old May 25, 2011 | 01:31 PM
Invalid_User's Avatar
How strong are these a arms. They remind me of a wish bone from a turkey that you snap in half.
Old May 26, 2011 | 01:24 AM
strongest thing out there...Aurora bearings FTW!
